Bravetti 35-396 Power Hand/Stand Mixer Logo
Posted on May 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Missing beaters Is it possible to buy replacement beaters?
Anonymous
Level 2:
Guru:
  • Expert 351 Answers
  • Posted on May 09, 2010
Anonymous
Expert
Level 2:
Guru:
Answers
351
Questions
Helped
220921
Points
811
Try this site for replacement beaters ..
http://www.euro-pro.com/europro/productdetail.aspx?pid=E6DC268A-EF52-4AB3-B332-7A8F5FD0AA85(Euro-Pro+Base+Catalog)
I need replacement beaters for a GE Hand Mixer?? Model #169204
Amazon reviews are very critical, but you actually can post questions on Amazon to ask if anyone knows where to buy.
It might be possible to buy a full mixer, new or used, and including the beaters cheaply due to their poor reputation, and then use the beaters for your appliance.
Example - already sold but if new would include the GE beaters.
https://www.ebay.com.my/itm/GE-169204-Digital-6-Speed-Hand-Mixer-w-case-NEW-/360758462539
https://www.amazon.com/GE-169204-Hand-Mixer/product-reviews/B0051CB6E6
1helpful
2answers
Need beaters for a black and decker SM100 mixer
I searched for replacement beaters for Blacker & Decker SM-100 type 1 (SM100) electric stand mixer for years. I found the Sunbeam Mixmaster Mixer Replacement Beaters for stand mixers, item 4955, at a large Ace hardware store. They were priced over $16.00, so you may consider buying a new stand mixer. The beaters are the correct length, snap in and grip correctly even though the ends are curved like a half ball rather than flat as the originals. The beaters turns well but I haven't tested them with the bowl because I need to find the turn table that I have in storage. The beater set was design ed to replace parts for Sunbeam stand models 2355-1, 2356-1 and 2360-2.
Bread dough beater will not come off
Make sure your Beater can slip in and out of the Beater Shaft
easily. Do not force the beater onto the Shaft if the shaft is bent.
If it cannot be removed easily by hand, use a soft rubber mallet
(not a steel hammer) to slightly tap the beater so it can be moved
up and down the shaft or from side to side. Then you can easily
turn the beater left and remove it from the shaft.
From Kitchenaid Manual:
To Attach Flat Beater, Wire Whip, or Dough Hook
1. Turn speed control to OFF.
2. Unplug stand mixer or disconnect power.
3. Tilt motor head back.
4. Slip beater onto beater shaft and press upward
as far as possible.
5. Turn beater to right, hooking beater over pin on shaft.
6. Plug into a grounded 3 prong outlet.
To Remove Flat Beater, Wire Whip or Dough Hook
4. Press beater upward as far as possible and turn left.
5. Pull beater from beater shaft
2answers
Need replacement beaters for Rival 12 speed stand mixer. I am unable to find any 89-attachments for this mixer as I have misplaced the beaters that came with the unit. I've looked everywhere. Are...
I cant find any information online at all about buying attachments for my new Rival 12 Speed Blender!! Does anyone know how I would find out how I could go about ordering new parts for it?
4answers
I have a Kitchenaid 550 watt 6 qt. stand mixer model #KB26GIXER. I tried to use it this morning and couldn't get the beater blade to lock in place. Isn't there supposed to be a spring and washer...
There is only one pin on the beater shaft to hold the beater in place.
There is no spring or washer on the shaft.
To Attach Flat Beater,Wire Whip, or Spiral Dough Hook, simply
1. Slip flat beater on beater shaft.
2. Turn beater to right, hooking beater over the pin on shaft.
1helpful
2answers
We have a Cuisinart Hand Mixer Model # HM70 and the Beaters do not stay in the mixer holes. Can this be fixed in any way? Jack
Cuisinart hand mixers are not repairable. You can buy replacement accessories like beaters, but you can't buy any internal replacement parts.
I have a Cuisinart HM-70 and I stripped the plastic gears inside by trying to mix a really thick dough. It was easy to open and get to the plastic gears. When I called Cuisinart to try to get replacement gears, they said that they don't sell replacement parts and their hand mixers are not repairable. I looked all over the internet and no one sells internal parts.
Unless your mixer is still under warranty, I believe that you're out of luck and your mixer is headed to the electronics recycle pile.
Most handmixers today are sold with plastic gears - including high end brands like Viking. For me the lesson learned is to buy low end hand mixers (don't buy a top of the line 9 speed mixer) and treat them like they're disposable when they break.
2answers
Missing beaters
try this site for your beaters ..
1helpful
2answers
Unable to find replacement beaters
Hi. I can't find a parts place that carries your parts or attachments, let alone any hint of your mixer's model #. What I did find is White Westinghouse's toll-free telephone # 1 866 942-0437. Ask them about replacement beaters and. other parts. You may be out of luck as this company's products are made by licensed manufacturers, quality and parts availability may be sketchy.
If this solution has assisted you, please rate it. Good luck! ricardok45
Apr 13, 2009 • Food Mixers
I need replacement beaters for a dough hook stand mixer
Information from manufacturer stating replacement parts have been exhausted.
Jan 30, 2009 • Food Mixers
1helpful
4answers
Replacement beaters
I had an SM100 which did not work when I got it out to make cookies recently. So, I have both bowls available (large and small), beaters, dough hooks, whisks and the use and care book too! I sure will miss that mixer. Contact me at lindareagan@comcast.net
Top Bravetti Food Mixers Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Bravetti Food Mixer Expert? Answer questions, earn points and help others
