If you were going to tap into the factory radio turn-on, unless you are working on a BMW or better, I would not use the fuse approach. Granted it gets the job done, but it would never be a secure as going behind the radio and hooking it up right. If are using the factory radio let me know and I can tell you the right wire to hook up to. I hope I can help.
-Andrew Hawkins
Well really u can take the remote wire from the amp to a kill switch mount it on the dash and then the kill swicth to the fuse box. put it on the fuse that says radio hook the remote wire up to that and remember that when u wrap the wire around the fuse make sure that it stays in place . or u could have a bad ground its one of those though and u dont really have to run a swith or a kill swicth u just go srtight from the amp to the fusebox under the dash let me no if any if this info works.
By saying that your remote is wrong, what do you mean? Does your remote wire not have 12 volts on it when the radio is on? If you want to turn your amp on run a wire that is either switched with the ignition or a switched output from the radio to turn it on. Or you could just run 12 volts to a switch and then the switch to the amp remote. That way you can turn it on and off when ever you want...your preference. I hope I could help.
-Andrew Hawkins
