Sharp AL 1631 Copier Logo
Posted on Apr 03, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Adding developer Where and how much developer is required by the Sharp AL-1631. Ordered developer and they delivered a 190 gram bottle that is supposed to be 6 charges worth. Do I add only 1/6 of the 190 grams to the toner? Thanks for your help.
  • fishinpole Apr 07, 2008
    Just want to add developer. Adding toner to cartridge is simple task. Just remove 4 screws and pour in toner. I don't know how to handle the developer! Thanks for your help.
  • fishinpole May 01, 2008
    Based on advise received, I did the following. Just to the right of the "big" plug (where the toner is added), there is a smaller plug where the developer is added. I removed the small plug and rather than take a chance damaging any sensor, I simply shook the cartridge to remove all the old develpoer I could. Once empty, I added 190 grams of new developer. I then removed the big plug, shook the unit to remove all the old toner I could. I then added 22 grams of new toner. I re-installed the unit and the machine is working perfectly. Just as good as when brand new. The "6 charges" of developer means that the developer will work for 6 changes of the toner. Once you refill the toner 6 times, it's time to change the developer. Thanks for all the input, help and advise.
Anonymous
Level 1:
  • Contributor 42 Answers
  • Posted on May 01, 2008
Anonymous
Contributor
Level 1:
Answers
42
Questions
0
Helped
14643
Points
67
Do not vacuum developer from these cartridges unless you want to blow the TDC sensor this will cause your copier to constantly feed toner and make a mess.
I place the cartridge on end after disassembling and rotate magroll by hand and wipe/ brush developer off roll until almost completely bare roll shows.
then fill up w/new developer by carefully pouring developer on magroll when cartridge is sitting on it's left side and roll faces up turn roll slowly while evenly pouring developer on roll.-no need to split cartridge.
then refill toner using provided spout
do not forget to vacuum clear waste sump on front of cartridge or you WILL have a mess.
Reassemble and test-these are good for many recharges.
we have done hundreds of them sucessfully with only an occasional defective ctg
Never overfill the toner hopper or tap it down multiple times and try to get more in than specified.
and finally use a hepa filter or toner approved vacuum.
A
Anonymous
190 Grams is the exact amont of developer required. Disassemble the cartridge by removing the green handle (2 screws),Black cover under that(2 screws),.Ten under that remove the 2 screws in order to separate the cartridge by lifting and pulling slightly.The top half has two pins petruding from it on the rear and there are no screws on the rear.Dump/vacume or blow out all old developer.Pour in 190g of new developer. Patially reassemble cartridge and then fill with toner 220g of toner by removing larger plastic plug.Reassemble install and allow the machine to cycle till ready.
Anonymous
Level 3:
President:
  • Master 2,072 Answers
  • Posted on Apr 03, 2008
Anonymous
Master
Level 3:
President:
Answers
2072
Questions
0
Helped
1124784
Points
5836
If you buy a new toner cartridge the developer is already in it.
Are you mixing ink and toner to rebuild cartridges?
If your just a user, once you replace the toner cartridge you have added new ink with the developer in it.
If you are not mixing and rebuilding the toner cartridge, and installing a new one, You do not need developer.
  • Anonymous Apr 07, 2008
    I went to a site and read the info. Yeah weigh out 1/6th the weight and install it. Shake the cartridge well after.
    What the developer is, is a magnetic material the the toner adheres to and applies it to the mag, roller then to the drum.
    Just be sure you vacuum out the old developer from the cartridge.
    That should take care of things for you.
  • Anonymous May 01, 2008
    Hey thank you for the info.
    I had not seen that procedure for that cartridge.
    Thats great to know.
    Thanks again.
Top Sharp Office Equipment & Supplies Experts
George Mclaughlin
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
