Dyson Memory CRO1 Front Load Washer Logo
Posted on Aug 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have error code f13, can you help, please..
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 07, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1043
Points
11
This s is how i fixed the F-13 Fault on my Hotpoint WD 640 washer dyer. Simple to fix just see the pictures and explanation. Hope this clears things up
Boxie
i have error code f13, - 1_7_2013_12_28_59_am.jpg1_7_2013_12_31_38_am.jpi have error code f13, - 1_7_2013_12_31_56_am.jpgrc=
  • Anonymous Jan 07, 2013
    Sorry pictures are to low a resolution and are unclear, sorry. Cant seem to change them!!! Send me an email and i will post them to you :)
Anonymous
Level 1:
  • Contributor 27 Answers
  • Posted on Aug 08, 2010
Anonymous
Contributor
Level 1:
Answers
27
Questions
Helped
15006
Points
55
F13 means not heating
the element may be faulty or the wiring to it
flooding gives fault f14
  • makathjem Dec 06, 2010
    F13 is the heating element. It is at the bottom of the drum at the front. If you know how to remove the front panel then it is reasonably easy to change. You can also test the continuity before you change it. I got a new element for under 20GBP. The element is held in place by the bolt on the earth point. It takes a bit of working to get it out as the rubber seal is deformed as it is installed in order to make a tight seal. I ended up removing the front of the drum as well. About 3hrs DIY work start to finish so perhaps worth the call out fee.
Oloyede Monsuru
Level 3:
An expert that gotĀ 20 achievements.
An expert that gotĀ 10 achievements.
  • Master 1,468 Answers
  • Posted on Aug 07, 2010
Oloyede Monsuru
Master
Level 3:
Answers
1468
Questions
0
Helped
415057
Points
4012
what f13 indicate means an error code that there have been an over flow of water from the drum over to the panel or the wire that suppl power to the screen .
what you will have to do to fix up this problem from the screen is to unscrew the screws with screw driver care then trace the wire ,that is the power supply down to the panel and also to the screen clean up all forms of liquid around the wires and also the panel carefully . then couple it back with care to is position with this the problem is solve.
thank you.
Top Dyson Washing Machines Experts
AskDyson
AskDyson
ADMIN Andrew
ADMIN Andrew
Are you a Dyson Washing Machine Expert? Answer questions, earn points and help others
