Baumatic B904SS Stainless Steel Electric Double Oven Logo
Posted on Aug 09, 2010
How to remove and replace Baumatic BT2760ss main oven element
5 Related Answers
Anonymous
  • 135 Answers
  • Posted on Aug 06, 2007
SOURCE: Baumatic b180 oven
The oven cabinet is likely built for several different models, which means that the case could have been built with an extra hole or two that aren't used on your model. This a normal manufacturing technique for mass-product factories. I see from the Baumatic website that several of their models do use a meat thermometer probe, but even if you bought a probe you couldn't use it your oven. Your model doesn't have the correct circuit board and control panel that the oven needs to use the probe. In any case, if you need to order parts from the manufacturer or would like a downloadable Owners Manual for your model, they are available at this website link: http://www.baumatic.co.uk/products/discontinued-models/builtinovens/B185SS-B Hope that helps! ;)
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Nov 30, 2008
SOURCE: fan oven not heating up
If fan is working then the element has probably gone
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Jan 13, 2009
SOURCE: Beaumatic B151SS Single Oven Problem
Disconnect the element, and run the oven for at least 30 mins,,if it does not blow fuse, then more than likely it is a faulty element.
What I cannot understand is that you say the thermostat light is on after the fues has blown? I would have thought that the light would be not be on, if the fuse has blown.
If after replacing fuse and the stat is in the off position, and the indicator light is on then indeed the stat is faulty.
Plz rate my solution.
Thanks.
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Feb 08, 2009
SOURCE: Baumatic 720 Double Oven - Door has come off hinge.
If you got to:
www.youtube.com
Then click on youtube videos, and in the search box type in: fitting oven door hinge, you should be able to get all the info you need to help solve your problem.
Please leave a fixya rating for my suggested solution.
Thanks.
Anonymous
  • Posted on Jul 23, 2009
SOURCE: Fan Oven blows Fuse over 175 Celcius -Baumatic BT2760SS
Hi, I was cooking and my oven jut went off, looked in fuse mains box and had tripped. So put back on and now the fan works but no heat...Can you give me some idea what it mite be.
Top Baumatic Ovens Experts
ADMIN Andrew
ADMIN Andrew
Simon Atkinson
Simon Atkinson
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
