RIM Research In Motion BB8900CURVE Curve 8900 - Unlocked Cell Phone Logo
Posted on Aug 12, 2010
Uncaught Exception: Java.Lang.error - RIM Research In Motion BB8900CURVE Curve 8900 - Unlocked Cell Phone
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 29, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
496
Points
Option -> Advance Option -> Application -> (Application that you have just installed) -> (Menu Button) -> Edit Permission -> Check (Set) Allow All (Check All) -> (Menu Button) -> Save -> Reset Device (Remove Battery & Restart) -> Now start the program
3 Related Answers
270rexton
270rexton
  • 782 Answers
  • Posted on May 13, 2009
SOURCE: can't play java on my htc touch hd
In general WinMo doesn't support Java. You need application called Esmertec JBed which will run JAVA on your device.
Anonymous
  • Posted on Jun 11, 2009
SOURCE: I keep getting this error on my BB Storm 9500.
I had this same problem for months and couldnt figure out why. Then I just completed the latest update and it is now gone!
Anonymous
  • 87 Answers
  • Posted on Nov 19, 2009
SOURCE: uncaught exception: java.lang.nullpo inter
Hi, you get this error message when attempting to access a corrupt contact list database on the BlackBerry smartphone, BlackBerry Device Software or software application component has failed, or there is corrupt data from a wired or wireless synchronization.
Isolate the corrupt data by turning on advanced logging for Intellisync
1) Turn on advanced logging for Intellisync.
2) Once the corrupt data entry has been isolated, delete it from the desktop email client and the BlackBerry smartphone.
3) Synchronize again.
Clear the contact list database on the BlackBerry smartphone.
1) Open BlackBerry Desktop Manager.
2) Click Backup and Restore, and then select Advanced.
3) From the Device Databases list, select Address Book, and then click Clear.
4) Return to the BlackBerry Desktop Manager window.
5) Synchronize the contact list with the correct translator in Intellisync.
I hope this information will help you
5helpful
2answers
Uncaught java.null. exception every time mention after I reboot my bold 9700
Can you use the BlackBerry, or is it locked up? It sounds like an application error -- did you just download or install a new application or game? If so, uninstall it and see if the error message goes away.
You can also try clearing your Java cache and all temporary files to see if that clears it up. Have you tried a battery pull?
Says that a uncaught exception:java lang.nullpoinereException
suppose you have declared a array of 5 ( ie 0-4 ) and you are entering the value for 6 or we can say more than 5 then you will receive this error and also you have not declared the catch block or exception block for this exception to handle the error .
5helpful
3answers
Describe your Uncaught exception java lang
I need to know how to reset or wipe clean because i cant get jpast this message at all uncaught exception:java.lang.nullpointerexception i cant do anything help
1helpful
I keep getting the message "Uncaught exception Java.lang.null pointer exception" and cannot use the phone at all. Any ideas?
Hi, When attempting to access a corrupted call list database on the BlackBerry smartphone, the Uncaught exception:java.lang.NullPointerException error message appears: Isolate the corrupt data by turning on advanced logging for Intellisync. Turn on advanced logging for Intellisync. Once the corrupt data entry has been isolated, delete it from the desktop email client and the BlackBerry smartphone. I Hope it helped you. Thank you for using ' Fixya ' and have a nice day!!
1helpful
Can't check missed calls shows Uncaught Exception:java.lang.null
  1. Turn on advanced logging for Intellisync.
  2. Once the corrupt data entry has been isolated, delete it from the desktop email client and the BlackBerry smartphone.
2helpful
BB messenger error "Uncaught Exception: java.lang.null...
When attempting to send messages from the BlackBerry device, the BlackBerry device user receives the following Java error called uncaught exception java.lang.illegal argument exception:
To over come this error you need to complete the following steps:
First, perform a full backup of the BlackBerry device data:
  1. Connect the BlackBerry device to the computer using the USB cable.
  2. Open BlackBerry Desktop Manager, and then double-click Backup and Restore.
  3. Click Backup.
  4. Save the backup file.
Run the application loader tool and erase all data on the BlackBerry device:
  1. In BlackBerry Desktop Manager, double-click Application Loader.
  2. Click Next.
  3. On the Device Security Password screen, type the BlackBerry device security password, and then click Next.
  4. On the Device Application Selection screen, click Next.
  5. On the Completing the Application Loader Wizard screen, click Advanced. The Device Data Preservation screen is displayed.
  6. Select the Erase all application data check box, and then click Next.
  7. Select Do not automatically back up and restore the device application data during the loading process, and then click Next.
  8. Click Finish. The BlackBerry device resets. This might take several minutes.
Hope I helped you.
Thanks for using ' Fixya ' and have a nice day!!
7helpful
7helpful
Can't play java on my htc touch hd
Top RIM Cell Phones Experts
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
