When attempting to run Microsoft .Net based applications, you may get the following error on startup:
The application failed to initialize properly (0xc0000135)
The cause of this error is that the Microsoft .Net framework is not installed or is damaged in some way. Therefore applications will fail to launch.
To fix this
error you can run Windows Update and find the Microsoft .Net framework
update to install. Alternatively, you can download the Microsoft .Net
Framework directly from Microsoft.
You need Microsoft .NET 2.0 installed. You can download this from Microsoft's website.
SOURCE: about the InfiniteL2Patcher.exe
You need to install Microsoft .NET Framework.
It can be found [here].
Cheers
SOURCE: Roblox dhg program will not run
The program that you downloaded is broken. This may be due to improper downloading (i.e. with a 56k modem over windows standard download). Please use mozilla firefox and download through it or download a Download manager. Furthermore, confirm that this program is actually intact and funtional by the uploader. If your internet speed is not that high (64 128) i would suggest you download the program without browsing or "just let it download without doing anything else".
