Posted on Aug 23, 2010
Where do i find the transfer belt on samsung CLX 2160? How do i replace it?
5 Related Answers
Anonymous
  • 9 Answers
  • Posted on Jul 28, 2010
SOURCE: I need to reset the transfer belt counter
enter tech mode by pressing menu>idcopy>left>right>menu>back>menu ,then in data setup clear all memory and clear count
Anonymous
  • 9 Answers
SOURCE: replacement transfer belt on my Samsung CLX-2160 not recognised?
gggg
  • 904 Answers
  • Posted on Nov 27, 2010
SOURCE: How to fix transfer belt error for samsung printer
Did you try turning the machine off, unplugging it, then plugging it back in and turning it on? Usually this procedure will cause the error message to go away.
If the error does not clear, you'll need to call a service technician.
gggg
  • 904 Answers
SOURCE: transfer belt error samsung CLX-2160 help
The first thing to try is to turn the printer off, unplug it from the wall, then plug it back in and turn it on. If the error message goes away, you can resume normal operation. If the error message still appears, you'll have to call your service technician.
Anonymous
  • 1157 Answers
  • Posted on Jan 17, 2011
SOURCE: I have a Samsung CLX-2160 print. It says "transfer
Try this steps it might help,
1. detach the paper tray and push it back correctly.
2. open the front door and remove toner cartridges, on left inner side u may see a light sensor which detects the toner cartridges.. simply clean this section by a small cotton bud. and in the left side of toner unit there is a sensor door, behind that door there is also a light sensor bulb, which needs to be cleaned by a cotton bud.
Please rate this solution if found useful.
Thanks
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
