SOURCE: I have a Janome Memory
You have ended up in the Vacuum cleaner section, but if you look in your User Manual on page 71 you will be able to read about how this is achieved...feeddog switch, then rotate hanwheel one full revolution to re-engage.
Cheers
Bargain Box
SOURCE: I have lost my janome
Hi check this link for your manual
https://www.2instructions.com/search.php?cmarque=JANOME&modele=MS2028
SOURCE: My Memory Craft 6000 began
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.Don't forget to rate my answer
SOURCE: i have a Janome 360
http://www.youtube.com/watch?v=VZLXv_lh1GM
take a look at this video ..it is not the same model ..but the main idea is the same ..(and visual explaining is best ..
only this model has the frst part of the thread going under a lid ..but the threading is made the same way ..the only difference is that the spool will have a vertical position ..and will go first behind the top left ..
here I found a manual for it ..but it is not free..(it seams there are no free manuals available ...)
http://www.sewingmachinesplus.com/manual-j-360-361-ensp.php
it costs $10 and it is a downloadable file ..
SOURCE: My mom has alzheimers and
I wasn't able to locate an actual manual for your Janome 9000 Memory Craft sewing machine. Believe me, I searched! I was able to find assistance to issues from the Janome website. Goto http://content.janome.com/index.cfm/FAQ then scroll down to MC9000 then click on category in the FAQ section or just click on search. Their database is huge. There may be some assistance in those pages. You can also try http://content.janome.com/index.cfm/Machines/Retired/MC9000 I know its not a manual, its a start. I wish you all the best.
