Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
Posted on Sep 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i graph? - Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
k24674
Level 3:
  • Texas Instru... Master 8,093 Answers
  • Posted on Sep 09, 2010
k24674
Level 3:
Answers
8093
Questions
0
Helped
4761499
Points
21601
The fact that you are asking how to graph makes believe that you solved the problem about 'invalid dimension' . I am glad that worked for you.
This
should help you setup your calculator to do graphing.
1. Prepare calculator for graphing
Turn StatPlotsOff to avoid errors:
Press [2nd][STATPLOT][4:PlotsOff][ENTER].
2. Setup Graph type
  • Press [MODE] key.
  • In Mode set up screen, make set the angle unit (if you are drawing trigonometric functions)..
  • Use the arrows to move cursor to 3rd line to highlight degree or radian and press [ENTER]. The important thing is that you be aware of the unit so that you do not get unexpected results.
  • On same screen, verify that Func is highlighted. If you are drawing PARametric plots, POLar plots or SEQuence plots, you highlight the relevant item in the list
  • If it is not, use arrow to highlight Func and press [ENTER] to validate.
  • Do not worry if you do not have exactly the same screen as in the screen picture (We may have different OS Versions)
3. Entering the functions to draw (assuming you want to draw y= functions)
  • Press [Y=] to enter function editor.
  • Type in a function
  • Press [ENTER] at the end of each function.
  • Before pressing [GRAPH], make sure that all the = signs that define the functions to be graphed are highlighted white on black. If one is not highlighted, use arrow to move cursor on the sign and press [ENTER].
  • In the screen capture 4 functions are slated to be drawn.
4. Selecting the Graph Style (You may ignore this now, because it is unimportant for just one graph)
  • Select the graph style: The small piece of line to the left of a Y that defines a function is the style.
  • Move cursor on it and press [ENTER] .
  • Each [ENTER] (on same line) selects another style.
  • On the next screen you have all the styles available on the calculator.
  • Do not select the bubble on line 6: It is for animations. It will not leave a trace at the end of the plot.
    how do i graph? - 7ed82f0.jpgimg src="/uploads/images/7ed82f0.jpg" alt="7ed82f0.jpg" class="h_mi" />
    5. Drawing the Graphs
    • Press [GRAPH] to see the graphs.
    • If one of them is missing, verify that its = is still highlighted, then use the [WINDOW] to set the Window dimensions,
    • Here are the dimensions of the stahow do i graph? - 5c26e6c.jpgw
    6. ZOOMING
    Youhow do i graph? - 91c4f6f.jpgress [ZOOM] to adjust.
    The selection 6:ZStandard sets the dimensions as on the screen Titled Window (above).
Graph 1 2 on the number line.
https://www.youtube.com/watch?v=FHOE4EvYCm8
https://www.youtube.com/watch?v=IDG20QMlcm8
Graphing on a Number Line
Integers and real numbers can be represented on a number line. The point on this line associated with each number is called the graph of the number. Notice that number lines are spaced equally, or proportionately (see Figure 1).
Figure 1. Number lines.
Graphing inequalities
When graphing inequalities involving only integers, dots are used. Example 1 Graph the set of x such that 1 ? x ? 4 and x is an integer (see Figure 2).
{ x:1 ? x ? 4, x is an integer}
Figure 2. A graph of {x:1 ? x ? 4, x is an integer}.
When graphing inequalities involving real numbers, lines, rays, and dots are used. A dot is used if the number is included. A hollow dot is used if the number is not included.
Example 2 Graph as indicated (see Figure 3).
1.Graph the set of x such that x ? 1.
{ x: x ? 1}
2.Graph the set of x such that x > 1 (see Figure 4).
{ x: x > 1}
3.Graph the set of x such that x < 4 (see Figure 5).
{ x: x < 4}
This ray is often called an open ray or a half line. The hollow dot distinguishes an open ray from a ray.
Figure 3. A graph of { x: x ? 1}.
Figure 4. A graph of { x: x > 1}
Figure 5. A graph of { x: x < 4}
Intervals
An interval consists of all the numbers that lie within two certain boundaries. If the two boundaries, or fixed numbers, are included, then the interval is called a closed interval. If the fixed numbers are not included, then the interval is called an open interval. Example 3 Graph.
1.Closed interval (see Figure 6).
{ x: -1 ? x ? 2}
2.Open interval (see Figure 7).
{ x: -2 < x < 2}
Figure 6. A graph showing closed interval { x: -1 ? x ? 2}.
Figure 7. A graph showing open interval { x: -2 < x < 2}.
If the interval includes only one of the boundaries, then it is called a half-open interval.
Example 4 Graph the half-open interval (see Figure 8).
{ x: -1 < x ? 2}
Figure 8. A graph showing half-open interval { x: -1 < x ? 2}.
When I try to graph it says argument error
Your function is not correctly defined. If graph is function y=f(x), variable must be x; if graph is polar, variable must be theta, and if graph is parametric, variable must be t. This does not cover all possible cases. Check the graph type and the definition of the function.
Ti 84 plus wont graph
You might have used an inappropriate variable name.
For functional graphs y=F(x), the independent variable must be X
For parametric graphs, the independent variable in the x_t and y_t functions must be t.
For polar graphs the independent variable must be Theta, and for sequence graphs, it must be the special wiggly n.
Once you select the type of graph, the independent variable is entered by pressing the key marked X,T, Theta, n.
The Y-values listing is missing under the [2nd] graph button. Only the
If you want the table to be generated, you must use the table feature. You can generate a table also after you draw (graph) a function.
Enter a function in the Y= editor, then press GRAPH or SHIFT GRAPH (TABLE). If you press GRAPH, you will see a graph. If you want the table and are not interested in the graph, press SHIFT TABLE.
How do I get more than one graph to graph? The calculator is stopping me from turning more than one graph on.
After entering the first function to graph press the down arrow and when the cursor blinks after Y2 type in the second function you wish to graph. After you finished entering multiple functions make sure the graph setting under the window button are set correctly so every function will be visible at the interval you set. After that you hit Graph and you should see your graphs being plotted.
I hope it helps.
7helpful
3answers
How to draw graph using c++
there are nomerous way to make a graph in c++. you just have to now the code for it.. abse on my knowlegde there are on "for loop" statement that can be use in making a graph in c++.
11helpful
4answers
How to graph linear equation in two variables
I am not quite sure what you are asking...
(1) if asking for graphing y= -2/3x+2, then press [diamond] [F1: Y=] type in .2/3x +2, see graph by [diamond][graph]
(2) if asking for graphing y= -2/3x+a, where a=3x, then first archive a=3x in Home screen by [home], type 3x [sto] a, then go back to y= menu, and type -2/3x+a in Y1
(3) if asking for graphing an equation that is dependent on 2 variables at the same time, use x-y-z axis (aka, change mode to graphing 3-D by [mode]graph [5:3D]) then enter desired equation in y= menu using Z function in terms of x and y aka z(x,y)= ...)
Top Texas Instruments Office Equipment & Supplies Experts
Rommel Balcita
Paul Bade
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
