Texas Instruments TI-86 Calculator Logo
Posted on Sep 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the i button on the TI 86? - Texas Instruments TI-86 Calculator
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Texas Instru... Master 102,366 Answers
  • Posted on Sep 14, 2010
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10724326
Points
622696
There isn't one. If you're entering a complex number in rectangular form, separate the real and imaginary parts with a comma (left of the 4). If you're entering a complex number in polar form, separate the magnitude and the angle with the angle symbol (2nd comma).
2answers
How do I reset my TI-86 after a long period of no use.
Every time you change batteries this will happen to you. First press 2nd then press and hold the down arrow. Hold until their is no black in the background but you can still see the numbers on the screen.
My Ti-86 wont turn on after i change the batteries
This may sound silly but check that you put the batteries in the correct way round for (-) and (+)?
I have a ti3 and ti 86 but not got intructions for ti86 and was considering getting ti92 but not sure if the ti 92 is any better than what i have
That depends on what you need to do with the calculator. The TI-83 is better at some things, the TI-86 is better at some other things, and the TI-92 is better at yet other things.
The 83 and the 86 both use the Z80 processor, though the 86 is quite a bit faster. The 92 uses a 68000 processor. Though the 83 has a faster processor than the 86, the 86 has some additional calculus capabilities.
You can download TI's manuals from their support website.
There's a good comparison of present and past models here.
What is the different between ti-86 and ti-83
The 86 has more memory. It also has some advanced calculus capabilities the 83 doesn't. However you're much more likely to see examples for the 83 in textbooks and other references.
TI-83:
http://www.ticalc.org/basics/calculators/ti-83.html
TI-83 Plus:
http://www.ticalc.org/basics/calculators/ti-83plus.html
TI-86:
http://www.ticalc.org/basics/calculators/ti-86.html
Send program from one TI-86 to another TI-86
First, connect the two calculators with the unit-to-unit cable.
Prepare the receiving calculator: press 2ND [LINK] F2.
Select the item to send on the sending calculator: press 2ND [LINK] F1 F2. For each program you want to send, navigate to it using the up/down arrows and press F2. Press F1 to send.
4helpful
How to get exponents on an ti-86
Press the ^ button. For example 2 raised to the 4th power would be 2^4. I hope this helps you out.
2answers
A friend gave me a TI-86 graphing Calc. I wont turn on!!!
maybe try changing the small memory battery inside, I think its a cr1616 or cr1620. If this doesn't work use it as a paperweight.
IT-86 Both batteries removed, now dead
Use the TIconnect or TIGraphlink software to reinstall the programs. You will find the programs in the TI Program archives.
ftp://ftp.ti.com/pub/graph-ti/calc-apps/86/.
Hope it helps
2answers
How to open (remove) TI-86 Keyboard
There are screws on the back. unscrew those carefully and then pull the two sides apart and start cleaning. GOOD LUCK
Top Texas Instruments Office Equipment & Supplies Experts
Rommel Balcita
Paul Bade
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
