MSI KM2M Combo-L (MS-6738-010) Motherboard Logo
Posted on Sep 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can't boot the pc by CD ROM - MSI KM2M Combo-L (MS-6738-010) Motherboard
Brian Sullivan
Level 3:
  • MSI Master 27,725 Answers
  • Posted on Sep 16, 2010
Brian Sullivan
MSI Master
Level 3:
Answers
27725
Questions
Helped
5776703
Points
79191
Press either delete or f2 during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
hope this helps good luck
How to boot from a USB CD/DVD ROM MY System is Dell Optiplex 170L Thanking in advance
If you want to boot from a external cd/dvd rom here's what to do.
  1. Connect your USB CD/DVD ROM to your computer.
  2. After connecting, you must start from boot up. so Reboot your computer.
  3. You must go to your bios settings, so during boot, press DELETE or if it doesn't work reboot again and try F2.
  4. Now once on the bios settings, search for the boot device, or boot priority.
  5. You must make your USB CD/DVD ROM as First boot, or just place it at the top of the list.
  6. You can adjust the position by pressing (-)minus and (+)plus signs in your keyboard.
  7. Now once the USB CD/DVD ROM is at the top. press F10 to save the changes and click Yes.
  8. And that's it. Your PC will now boot from the USB CD/DVD ROM.
Goodluck, Hope my solution will help, Please give some feedback regarding my solution.
Thank you very much for using Fixya! Have a Great Day!
1helpful
Emachine T4060 -black screen-no cd-rom boot
If it is DVD Drive, then sometimes in BIOS you'll also find the option for DVD Drive together with CD Drive. Choose the correct one and boot your PC.
Please come back and vote for me, if this turns to be helpful for you. Thnx
2helpful
2answers
How can i boot from cd rom compaq evo n410c
HELLO THERE
If you go into bios and change the boot sequense to the cd rom first than the c drive than you should be able to just put the cd rom in the drive and turn off the computer and restart and when it turns back on it should say pressany key to boot from cd rom
and to be perfectly honest with you as long as this is a bootable cd rom you should just have to put in thecd rom and reboot the computer and it should come up just like i said earlier ok?
but if not do like i said and change the boot configuration so the computer boots from the cd rom first ok?
I hope that this has been very helpful for you
best regards mike
I have a Dell Dimension 4600. I need to re-install Windows XP Professional. The PC won't boot from the CD-ROM. When I choose F12, then Boot from IDE CD-ROM, the PC boots directly to Windows. how can I get...
Check the BIOS to make sure that the CD rom is the first boot devices in the bootup sequence, also make sure that the cd rom does show up in the BIOS.
Make sure that the CD Rom itself is good or the boot cd you are using is good, try it on other PC.
My acer PC does not boot from CD drive
if you want to boot your computer with cd you have to set first boot device in bios as your cd rom or dvd rom,
for that when you power up computer press F2 or "del" then you enter in bios then go to boot option then set first devcie as dvd or cd rom .
then save all settings then exit.
1helpful
3answers
My dell desktop doesn't start or boot from cd rom
Basically you need to go to Bios to change your "Boot device pripority". Please follow these steps to do this.
Please follow these steps to install XP on your PC.
1. Please start your PC with power button. At the very first screen, at the left down corner, you will see the button to be pressed to go to Setup i.e. Bios of the PC. For most of the PCs , it is delete button. For some of them, it is F2 also. So, after starting the PC press Del to go into setup.
2. After you enter setup of the PC, please go to Advance bios setup.
3. There you select Boot device priority.
4. here the first boot device priority should be CD ROM, then the HDD. Please see the instructions given at right down corner and select this priority.
5. After you rightly selected boot device priority as given above, Press F10 to save the changes and then press F12 to exit.
6. Now the PC will restart again, but be sure that you put win XP cd in the drive before it restarts.
7. Now you will see a note that : press any key to boot from CD ROM, so please press any key.
8. The PC will boot from the CD ROM now , now you can follow the instructions given on the screen.
3helpful
5answers
Want to Boot from dvd ROM
when the pc in post usually on dells bios there is a boot menu option it is usually f12
if you don't know what your doing in the bios it is not a good place to test your skills after pressing F12 just choose cd rom for boot
HP PC will not boot up
the first thing that i would do is see if you can go into safe mode and try booting from there . when it comes up choose the one that is already hilighted. if it still wont boot then open up the tower and unplug the power from the cd rom. if it is your cd rom i would go and by another one or return the cd rom.
hope this works
Top MSI Computers & Internet Experts
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
