Lenovo 3000 Y410 (59012354) PC Notebook Logo
Posted on Sep 19, 2010
How do i get to the one key recovery menu? - Lenovo 3000 Y410 (59012354) PC Notebook
Anonymous
Level 1:
New Friend:
  • Contributor 19 Answers
  • Posted on Sep 19, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
19
Questions
0
Helped
3750
Points
55
Hello. For a Lenovo 3000 Y410 notebook. You may enter the OneKey recovery menu by pressing the NOVO button while the notebook is powered off. You can use this to restore your C drive (or your primary partition) back to factory default configuration including the operating system and the software on it.
Where would the reset button be inside a laptop.
Disconnect the power, remove the battery then press and hold the power button for 15 seconds. Reassemble.
  1. Make sure the computer is turned off ("Shut-down" from the Windows Start menu)
  2. Remove any peripherals such an external mouse, keyboard, monitor, USB flash drive etc.
  3. Make sure the AC Adapter is plugged in and working.
  4. On machines with the F key numbers on the top edge of the keys and in White:
    • Press and hold the 0 (zero) key and power up the laptop.
    • Release the 0 (zero) key when the recovery warning screen appears.
    On machines with the F key numbers on the bottom edge of the keys and in Gray:
    • Power up the laptop.
    • When the initial TOSHIBA screen displays, press the F12 key to enter the boot menu.
    • Use the arrow keys to select the HDD Recovery option and press the enter key to begin.
  5. The TOSHIBA recovery wizard warning screen appears stating that when the recovery is executed all data will be deleted and the original factory software image will be rewritten. If the recovery process offers a choice of Operating Systems, select the appropriate one for you.
  6. After you are sure you have everything you want from the laptop saved, click Yes.
  7. When the Toshiba Recovery Wizard opens, the default and recommended option is "Recovery of Factory Default Software".
  8. After selecting your desired recovery method, select Next.
  9. On the next screen you may have recovery method options. The default and recommended method is to Recover to Out of Box state.
  10. Select next to continue.
  11. Follow the on screen instructions as you navigate through the system recovery steps.
  12. The laptop will restart multiple times and install the needed components.
2answers
How can i reset a toshiba satellite pro m15 s405
Most Toshiba laptops with come with the factory software recovery image stored in a special hidden partition on the hard drive of the laptop. The factory software recovery image allows the user to recover the laptop to its factory fresh condition as when it was new.
This partition may also be referred to as the Partitioned Recovery Method or Free Recovery option.
IMPORTANT: The recovery process deletes information stored on the internal storage drive. Be sure to save your work to external media before executing the recovery.
3answers
How do I reboot my Toshiba Satellite C55 without a
If your recovery partition has not been deleted you might be able to do it. See if you can access recovery mode
How to pattern lock micromax ninja a89 problem sellusion plz help me sir....
For this you will have to Hard Reset your phone. Do the following:
Micromax Ninja A89 Hard Reset
  • Press and Hold Volume UP + Power Key.
  • You see Recovery logo (Android Image).
  • Press Home Key to see Recovery Menu.
  • Now select Wipe Data/Factory Reset And Press Enter Key.
  • Now Select Yes -- Delete All User Data. And Press Enter Key.
  • Now Reboot Device.
Note: Your power key will act as Enter key while volume Up and Down keys will be used to scroll the menu up and down.
Aug 25, 2014 • Cell Phones
Unlocking problem
The easiest way to unlock your Android smartphone now is to completely reset it. Doing so will erase all your settings and files that are not stored on the memory card.
Depending on the model and maker of your smartphone (Samsung, HTC, LG etc.) the procedure might be slightly different but the idea is to enter tAndroid Recovery Mode and wipe all data + cache.
For example, to enter Recovery Mode on Samsung Galaxy S2 you need to:
1. Turn off the phone
2. Press Volume Up + Power button until it starts (here is the key difference. The keys needed to be pressed are different. Search on google for [SMARTPHONE_NAME] recovery menu ex: HTC Desire HD recovery menu, Samsung Galaxy S3 recovery menu, etc) 3. The Recovery Mode should show up in some seconds
4. Using the volume keys, select Wipe Data / Factory Reset and press menu or power to select.
5. Select "yes" using the same navigation as from step 4.
6. After resetting, it will return to main recovery screen. Do the same for cache partition
7. After cache partition reset is done, select Reboot
8. Phone reboots and now you'll have to set everything up again, but at least the password is removed.
I need to press a key on my keyboard to start factory recovery
Hi and welcome to Fixya!
In order to revert the machine back to its factory setting, you need to have the recovery disk (if you don't have it, call the warranty support line of e-machines so they can provide it to you).
To restore Windows from your recovery discs, you will need to
insert the first backup disc and enable the F12 Boot Menu via the BIOS Setup
Utility.
1 Turn on your computer and insert the first system recovery disc into the
optical disc drive. Restart your computer.
2 During startup when the eMachines logo shows, press the F2 key to enter
BIOS Setup, where you can set system parameters.
3 Use the left and right arrow keys to select the Main submenu.
4 Use the up and down arrow keys to select F12 Boot Menu.
5 Use the F5 or F6 key to change F12 Boot Menu to Enabled.
6 Press the ESC key to enter the Exit submenu, press the ENTER key to Exit
Saving Changes. Press the ENTER key again to select Yes. The system will
reboot.
7 After rebooting, when the eMachines logo shows, press the F12 key to
open the Boot Menu. Here you can select which device to boot from.
8 Use the arrow keys to select the IDE1*, then press the ENTER key. Windows
will be installed from the recovery disc.
9 Insert the second recovery disc when prompted, then follow the onscreen
prompts to complete the restore.
10 Remove the recovery disc from the optical drive once the restore is
complete. Do this before rebooting your computer.
Hope this helps!
Takasashi
5helpful
How do i reboot or recover my nb505 toshiba netbook
Reinstall Windows from a Disk
1 Turn on your Toshiba . Insert your recovery disk or the original Windows operating system DVD
into the 's CD/DVD drive. Turn off the computer.
2 Turn on the Toshiba . In the first few seconds while it is starting up, press and hold the F12 key on your keyboard to access the Boot Menu. (Note: Some Toshiba models may tell you to press "C" to boot
from the CD-ROM). The screen will display boot for this boot up session only.
3 Use the arrow keys to navigate. Select the CD-ROM/DVD drive to highlight it. Press "Enter." Be aware that this setting is for this session only; it is not a permanent change.
4 Allow the computer to start up. Follow the onscreen instructions for reinstalling the operating system from the disk.
Reinstall from a Recovery Partition
1 Boot up the Toshiba . In the first few seconds while it is starting up, press and hold the F8 key. This will begin the "Advanced Boot Options" menu.
2 Use the arrow keys on your keyboard to navigate the menu. Move the keys to select "Repair Your Computer." Press "Enter."
3 Select your language and keyboard; click "Next."
4 Select your Windows user name from the drop-down menu. Enter your password if required. Click "OK." This will begin the "System Recovery Options" menu.
5 Select the Toshiba Recovery Wizard and follow the onscreen instructions. The Toshiba Recovery Wizard will delete all existing data on the hard drive and reinstall Windows.
Hope this helps!
2helpful
Key fo starting recovery partion
Dont know what model you have. Do you have a recovery partition which is accessed using F10 or F11 key at startup, or from recovery disc which is used from the start menu recovery option?
21helpful
3answers
Trying to do a full factory recovery on an M Series gateway note
If you want to do the factory recovery, 3 ways to do the system recovery
First way
1 login to windows
2.click Start
3. click All programs
4. click Gateway
5. click gateway recovery manager
6. click restore
7. select systems recovery to factory defaults
Computer will restart itself and start doing the system recovery itself, All you need to do is follow the screen
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
