Computers & Internet Logo
Posted on Mar 26, 2017
Big problem Hi, I want to make a linux based driver for my MODEM.I have a driver for my modem but it is windows based. I want to install that driver on one of the device which is called VCU(vehicle control unit). And I want to make communication between my Modem and VCU serially.I want to capture some file from the VCU through Modem and then wirelessly I have to send those file to my laptop wirelessly. In short It's like Between Modem and my PC it should be a wireless communication and beetween modem and VCU they are connected through serial port. And my modem and the VCU they both will placed inside LOCOMOTIVE. I don't how to go futher. can you suggest me some thing I will be very very thankful to you.
5 Related Answers
Anonymous
  • 8 Answers
  • Posted on Oct 19, 2007
SOURCE: SPEEDTOUCH 576 WIRELESS MODEM driver
HERE is the manufacturer main link to download driver.
page also has manual on installing it and config modem properties.
http://www.thomson-broadband.co.uk/codepages/content3.asp?c=7&ProductID=511
Anonymous
  • 68 Answers
  • Posted on Jun 23, 2008
SOURCE: Installing wireless connecton with an Arris modem
what type of modem are you using? You should be using a router which is capable of wireless connectivity....
Keep me posted
Cheers
A
Anonymous
  • Posted on Oct 16, 2008
SOURCE: modem driver for Huawei FWT Wireless Modem
follow...
http://www.openpages/info
there is a link for FWT config
Anonymous
  • Posted on May 14, 2009
SOURCE: The port the modem is attached to could not be opened; Opening the modem device failed with error 000005aa
Sounds like a hardware problem
First > try changing the modem port (default is com3, try changing it to com4 or com5 whichever is free)
Try querying the modem again
Second > Contact your modem manufacturer
Anonymous
  • 70 Answers
  • Posted on Jul 16, 2009
SOURCE: trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Top Sierra Wireless Computers & Internet Experts
Anonymous
Level 1 Expert
JDTec
JDTec
Are you a Sierra Wireless Computer and Internet Expert? Answer questions, earn points and help others
