Linksys WRT300N Wireless Router Logo
Posted on Oct 02, 2010
How can i lock my router - Linksys WRT300N Wireless Router
Anonymous
Level 1:
New Friend:
  • Contributor 33 Answers
  • Posted on Oct 02, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
33
Questions
0
Helped
11028
Points
81
1. Use an ethernet cable to connect a computer to any one of the four LAN ports of the linksys router.
2. In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
3. When prompted for a Username and Password, enter the default username and password , unless you have already changed it.
4. Select Wireless Settings from the Setup menu in the left-hand navigation bar.
Under SSID Name, Give a Unique name for Wireless N/w
5. Under Security Options, select WPA-PSK (Wi-Fi Protected Access Pre-Shared Key).
6. Under Security Encryption (WPA-PSK) > Passphrase, enter a passphrase.
7. * The passphrase may either be a string of 64 hexidecimal digits, or word/phrase of 8-63 ASCII characters.
* SAVE or KEEP NOTE of the passphrase - it will be required to connect wirelessly to your network.
8. Click Apply to save your settings.
9. Scan and Connect to your Wireless N/w on your Wireless Computer with your Password
2helpful
Maximum Router model 54-6810-8. Plunge base locked-will not plunge?
you can take to troubleshoot the issue:
Check the Lock Lever: Ensure that the lock lever is fully loosened. If it's tightened, the plunge base won't move freely. Loosen it completely.
Stability: Tighten the locking arm for stability. This ensures that the router remains secure during operation.
Motor Pack Removal: If the plunge base is still stuck, unplug the router and remove the motor pack from the plunge base. Follow these steps:
Unplug the router.
Loosen the lock lever.
Carefully remove the motor pack from the plunge base.
Remember to follow safety guidelines while troubleshooting and handling the router. If you encounter any issues or have further questions, feel free to call the toll-free helpline for the device at 1-888-670-6682
3helpful
2answers
How do I lock my Belkin wireless router?
You can lock your router by setting a password to access it. This is done in your router setup, in the Wireless area. I prefer WPA-PSK [TKIP] for the ease of setup and password selections. This should keep unwanted access to your wireless signal.
Card doesn't connect to router.
This could be cause by many things. Check your router and see if there are any wireless security or locked mac addresses (locked networks).You can always reset the settings it by pushing and holding the reset button at the back of the router. Also, is the card able "see" the router? If it cant "see" the router, you are probably not in range that the router, once again, has a locked network.
I need help on how to replace bit on router craftsman style
You didn't state the model number. The older Craftsmen routers had a red lever lock on the top of the router, one position allows the spindle to turn, the other position locks the spindle. Here's the instruction for the older style routers:
  1. Unplug the tool.
  2. To lock the spindle press the red button in and slide it to the locked position.
  3. Unlock the height adjustment knob.
  4. Raise the router motor using the height adjustment collar until you can get a wrench onto the collet nut.
  5. Loosen the nut until it turns freely.
  6. The bit may still be locked in the spindle, tap it gently (not on the blade!).
  7. The bit will come loose in the spindle and can be removed.
  8. Replace the bit, tighten the nut snug but don't use excessive force.
  9. Unlock the spindle, returning the red lever/button to the free position.
  10. Adjust the height of the bit as you wish, then lock down the motor using the locking knob.
4helpful
Need to lock my router
I'm not sure if this is the correct model, but the steps should be similiar. Please follow the link to the belkin website and follow their instructions:
http://www.belkin.com/support/article/?lid=en&pid=F5D7230-4&aid=10177&scid=0
Router won't lock
u have to reset your router check in back side of router 1 reset button press it for 5 second then it restert and reset.
My router is now locked and i didn't have it locked how do I unlock it
there is no lock down on belkin router.
do you have router portected? if not, some one lock your router.
the best ting to do is reset it to factory default. and start all over again.
to that :
With the router powered on, use a small thin object to press and hold the reset button for exactly seven seconds. The router lights will flash and this will restore the router to factory default. Connect your computer to one of the routers lan ports with an etherent cable. Open your web browser and navigate to 192.168.2.1. This should show the router status page with the default settings.
Lock wireless interent connection
do u want to lock the router wirelessly?
if so may i know the model of the router..?
Lock handle on bosch wood router
Please have an expert take a good look at it, cos if proper care is not taken you might damage the device for good. good luck
Top Linksys Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Narseman
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
