HP Compaq d530 PC Desktop Logo
Posted on May 26, 2008
Proccessor problem my mother was very slow
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on May 30, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2504
Points
Esonic mother board ram problem. i was changed ram but still beeping. psu changed but still beeping. what i should?
Make sure that you are inserting the correct type of ram - many mo bo's are very sensitive to what you throw in there and will not work with just any ram. Put in the exact stuff called for by the manufacturer.
And are you sure it is a ram problem? There are beeps for other hassles other than ram. Check that out.
1helpful
I just got this Toshiba Satellite yesterday it was working fine but now when turn it on it keeps freezing. What should I do?
clean proccessor heat sinc if working well if not may dry solder in board if u r tecnition open laptop and reflow mother board
if fix your problem click yes for vote
This mother board support dual core proccessor
This motherboard is built with the Intel 845 chipset and is socket 478. This particular motherboard will not support a dual core processor of any kind. This board will only support a standard socket 478 Pentium 4 processor at best. I do not know of any that will support anything better than a Pentium 4 2.8GHz processor with a 400MHz F.S.B.
No display, i have already change my ram, processor, power supply but no result if i pull my ram replay ram beep from motherboard
no display is basically ram issue but condition that mother give u beep noise,
refix RAM proprely, chaque SMPS , PROCCESSOR,HARD DISK, Fixed togethar again ok resolve issue.
1helpful
Mother Board problem
use bios CD update bios on the mother board.ok
after that cpu fan...refix the cpu fan after cline,
apply the paste on the Proccessor.it working fine
When i put my computer in stand-by i get an error telling me that it had to shut down because a problem happend on the system
it means the problem with u r mother board. chaque the temprature of machine. if itis goes high upto 60 degree. refix proccessor fan After clin & paste, it reduce machine temp, reduce the chance of Damage,
Mother board soltek
www.motherboard.cz/driver/soltek.htm
Which should I upgrade?
Upgrade the RAM much easier to do than the CPU.
CPU requires you to find a processor that will work for your laptop motherboard then you gotta open it up and remove the CPU.... TOO MUCH WORK! unless you're very comfortable in doing this.
I would recommend go to 512MB to 1G of instead 256MB.
Drivers
Usually if you install an operating system you don't need drivers for a proccessor.
Top HP Computers & Internet Experts
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
