Whirlpool Duet WFW9550 Washer Logo
Posted on Oct 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code f70 - Whirlpool Duet WFW9550 Washer
Anonymous
Level 3:
  • Master 2,382 Answers
  • Posted on Oct 04, 2010
Anonymous
Master
Level 3:
Answers
2382
Questions
0
Helped
871444
Points
7450
F70 Error code means Central Control Unit Heartbeat Failure. If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the Central Control Unit to the User Interface.
F71 error code meansUser Interface Heartbeat Failure. If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the User Interface to the Central Control Unit.
In both the above situations the following things are required to be checked and replaced where required:
1. Continuity of the User Interface harness.
2. Wire harness connections to the User Interface and the Central Control Unit.
3. Replace User Interface if drum is rotating.
4. Replace Central Control Unit if drum is not moving.
1 Related Answer
tbirdfan1
Michael Thomas
  • 3056 Answers
  • Posted on Dec 26, 2009
SOURCE: F70 Error Code after initial wash. Unplugged
Hello there
Here is your Answer
Error code 70 means a Central Control Unit Heartbeat Failure. There is no
communication detected from the Central Control Unit to the
User Interface (the part that you touch in the middle to set cycles).
Possible Causes/Procedure
1. Check for continuity of the User Interface harness.
2. Check wire harness connections to the User Interface and
If these connections are ok then
3. Replace User Interface if drum is rotating. Part number is W10164402
4. Replace Central Control Unit if drum is not moving. part number is 8183259
Hope this has been very helpful
best regards michael
Getting code F70 and F71.
Hi.
Please read the tip below, explaining how to fix F70 and F71 problems. The comment applies to Whirlpool Duet washers like the one in question.
F70 and F71 are two logic board error codes that point at a communication error between the main log...
Regards.
Ginko.
1helpful
I got an F70 code . After unplugging the machine and then plugging it back in, I now get an F71 code. What to do?
Hi.
Please read the tip below, explaining how to fix F70 and F71 problems. The comment applies to Whirlpool built kenmore washers like the one in question.
Regards.
Ginko.
Getting code f70 & f71 washer will not run water does not fill or spin
Hi.
Regards.
Ginko.
There is an error code f70 and there was an error code f71.
Hi.
Regards.
Ginko.
Narseman
