SOURCE: casio pathfinder SPF 70-s titanium band adjustment
The schlatter.org solution is for the other type of casio band I've run into.
The wristband with the arrows has a fine pictorial solution at http://www.wikihow.com/Adjust-a-Casio-S-935L-Watch-Band
Basically you use a very very fine poker to poke the pins out in the direction of the arrows.
NOTE: you can't poke them out if you will drive them into your work surface, so think about that before you start.
SOURCE: How do you adjust the watch band(remove the links)
This may seem simple to do but it is literally a ***** of a task. Best to where amplifying glasses and use a ball point pen, not a pin or pencil. Push one side of the pin in while keeping a slight outward pressure on the band. When it releases be care full not to let it fly off into the void(which they can) and then move to where you need the band to be and reinstall using a single edge razor blade. Just carefully align the opposite side (assuming youve alredy put one end in)place the razor blade on center and slide the remaining pin into the hole area pull the blade out slowly and listen for it to click into place.
SOURCE: Adjust-a-Casio-S-1087DY-Watch-Band
On most brands, there are pins that form hinges for the links of strap. You need to push them out to remove links. Usually you would find arrows marked from inside of the metal bracelet which show you the direction in which to remove the pins. You can remove it if you have a small watch maker's screwdriver but you have to be careful. or get one of these ..
http://www.amazon.co.uk/Watch-bracelet-link-adjuster-remover/dp/B001ZKIL2S/ref=sr_1_1?ie=UTF8&s=watch&qid=1254695541&sr=8-1
which should help you to remove the link pins safely without scratching.
SOURCE: need to adjust length of watch band: Casio WV-57H
Check out my TIPS here and you will find out how to do that
