Hello
You have only stated that the height of the picture of your TV is less. Check whether your TV is working on "wide" mode. The mode should be set to "normal" for a full screen picture. There may option to turn the mode; through remote control handset of your tv. Select it, after entering into menu option and check. There are normally 3 modes will be displayed. "NORMAL, WIDE, ZOOM". You have to select "Normal" mode. If this does not helps, your TV needs height adjustments. It can be done only through some code send to the tv via remote. It is known as "service code". It is uneque code, and can be had only with the help of a well experienced technicin. If the problem pereists contact any one of such mentioned above.
gopakumarg43@ymail.com
gopakumar1@hotmail.com
