I found your drivers for you.
For Windows XP :
https://a248.e.akamai.net/f/674/9206/0/www2.ati.com/drivers/6-11-pre-r300_xp-2k_dd_ccc_wdm_38185.exe
Windows 7 or Vista 32 bit:
https://a248.e.akamai.net/f/674/9206/0/www2.ati.com/drivers/10-9_vista32_win7_32_dd_ccc_enu.exe
Windows 7 or Vista 64 bit:
https://a248.e.akamai.net/f/674/9206/0/www2.ati.com/drivers/10-9_vista64_win7_64_dd_ccc_enu.exe
Windows XP 64 bit:
https://a248.e.akamai.net/f/674/9206/0/www2.ati.com/drivers/10-9_xp64_dd_ccc_enu.exe
Please make sure you rate my answer 4 thumbs up, it is extremely
important to me. I would be forever grateful if you could do so. If
you need more help on this question please just respond to my answer
here and I will get right back to you.
Thanks
Tim
Step 1: Click the bottom left corner of your screen, start menu icon. No program is open, you do so. This will eliminate clutter, and make it easier to find what you need.
Step Two: Right click "My Computer" in your Start menu. (Vista users should right-click "Computer" from the pop-up menu, select "Properties.")
The third step: find the Hardware tab, click "Device Manager." (Vista users can click the left menu in the "Device Manager" Properties window. You do not have to click on a tab. Click "Continue" when prompted.)
Step 4: Select the type of item you want to find an updated driver. For example, if you select "Display Adapters", it will expand and show all of your computer display adapters. If you check for updates on all your equipment, start at the top and work all the way down.
Step Five: Right-click the specific device to update your PC drivers. Select "Update Driver" from the pop-up menu. This will open the Hardware Update Wizard.
Step Six: Choose the button next to "Yes, this is just" let the wizard connect to the Internet, and update your device drivers search. Click "Next."
Step Seven: stay in the "Install the software automatically" setting selected (if not selected, select it to switch). Click "Next." The wizard will now search for new drivers and install automatically if we find any. If your device is up to date, it will tell you it can not find a better driver for your device.
Step Eight: Click "Finish." Repeat steps 4 through 7 for each device on each extension option to update your PC on all the drivers.
What OS?
