You don't need to use the Vivitar software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
SOURCE: No software
http://www.opendrivers.com/driver/235270/vivitar-vivicam-3105s-twain-driver---stand-alone-utility-windows-free-download.html
software for your camera.
I appreciate if you rate me.
SOURCE: lost software
Thats good -
The software supplied with camera is usually more of a hindrance.
A Windows computer is quite able to accept images from the camera plugged to USB.
Windows will put up the the scanner/camera Wizard and ask what you want to do with them
the answer is load to a folder[My pictures is the default]
SOURCE: i need the software for Vivitar ViviCam 20 Digital Camera
Like all other Digi camera the provided software is not required to transfer images to a Windows computer
The computer will do this-
plug in the camera set to upload the computer will put up the Camera/scanner Wizard and asked where you want the images to go.
No Software Required
