Posted on Oct 28, 2010
Error code F202: This seems to be a toner issue. When a new toner was replaced error code still there. Copier will not copy.
5 Related Answers
Anonymous
  • 8 Answers
  • Posted on Dec 08, 2007
SOURCE: Minolta CS Pro Error Code C0070
Turn on and off WITHOUT toner bottle inserted to reset to home position. If message comes back, the toner motor/drive gears are busted. Time consuming repair, be warned!
Anonymous
  • 4402 Answers
  • Posted on Feb 19, 2008
SOURCE: Canon IR 3100 error code (E000020-0081)
Issue: ERROR LCD: System Error E000
1. Reseating the Fixing Assembly-ICMF 8100 2. Resetting the machine-ICMF 8100 3. Verify/reconnect power cord to fixing assembly
Anonymous
  • 148 Answers
  • Posted on May 26, 2008
SOURCE: F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
Anonymous
  • 446 Answers
  • Posted on Aug 16, 2008
SOURCE: Install Cyan Toner Error
ensure that the one you install is the exact model name and number, if this is correct, try unistallling once again and check one more time,
you might want to get a new cyan toner if this still fails, i dont think there is a prob in your machine, cheers
checkitright
CheckitRight
  • 1363 Answers
  • Posted on Sep 03, 2008
SOURCE: F2 error
"F2-31" Image density sensor fault "F2-32" Drum mark sensor fault "F2-33" Grid voltage correction problem "F2-35" Grid voltage correction problem "F2-37" Drum mark sensor fault
Top Sharp Office Equipment & Supplies Experts
George Mclaughlin
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
