The scroll lock key is next to the print screen and pause break
look at this image
http://docs.sun.com/source/800-6313-10/install.chapter3.fig.18.gif
Please dont be rude and rate a solution before we are done.. Il find this out for you one moment. We don't get paid to help people for free here!!!!
you will have to use the Function key, and look at the pause - break button you see that small icon there, that combined with the function key is scroll lock.
so press the FN key and pause break.
On the other side of the print screen
there is no actual button for scroll lock, it has been combined with the pause break button.
If you press the Blue FN button (hold it down) and then press the pause break, that enables or disables it.
I have a very clear picture of your keyboard here and I can see very clearly that there is a picture of scroll lock on the pause break button
This key has to be used while the FN key is pressed
This is a image of MS3200 logitech if this is not your keyboard kindly look at the bottom and tell me what do you see there.
sorry that is MX not ms
Please do change the rateing if your problem is solved or let me know if you need more help.
okey, theres another way to disable the scroll lock.
press start - run - type in osk
the on screen keyboard starts up
press the slk button with your mouse and scroll lock should be disabled.
could you change the rateing? Thanks.
No this is for a MX3200 Logitech keyboard
My key next to print screen is an "insert" key
I have an MX 3200 and this key is not on the keyboard. I do appreciate your help but my keyboard doesn't have what you are describing.
Your pictures are exactly correct. Only problem....when I hold down the fn key and press the pause/break it doesn't deactivate the scroll lock. All of your information seems correct and greatly appreciated, but it doesn't turn the scroll lock off. I've tried every combination, hold down fn key and press pause/break, press and release fn key, etc. Thanks for all the help.
Now that's impressive! I can't thank you enough!
