Computers & Internet Logo
Posted on Jun 23, 2008
Trying to make my pc wireless - Computers & Internet
  • Anonymous May 11, 2010
    So what is the question?????
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Jun 24, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
5459
Points
12
Purchase Asus (wireless lan )motherboard M2N32-SLI , wireless keyboard ,mouse , speaker thats all
Add wireless card to gateway sx2800-01
You add the printer to the router not the PC. Go to the manufacturers website for installation instructions. or follow the instructions on the disc. Set up is usually done with a wired connection anyway. But to make your tower wireless it is easier to add a wireless USB adaptor.
HOW TO TURN ON WIRELESS
Hi jerry is right, you have to make sure the pc is wireless capable. if not get a wireless card installed then try to install from the cd again
Trying to connect a router and it says my computer is not wireless
Good day,
Your PC might have no wireless lan, try using LAN cables and connect to your Network adapters to make your PC online, if you really need wireless connection, you can purchase USB wireless adapter to connect it with your router you can buy it in your nearest computer shops.
I can only use my router when I,m plugged into it
if you are sure its a wireless router and you cant find it with your pc then maybe your pc's wifi (wireless finder) is spoilt or your router is faulty. try using a different pc to try connecting using the wireless to help determine if the problem is from your pc or router
New wireless network trying to connect to unsuccessfully
Try going to Network and Sharing Center - Manage Network Connections. Click on the connection and enable it.
Also try Network and Sharing Center - Manage Wireless Connections, and moving the wireless connection you'd like to use and move it to the top of the list. Select any operations that will enable or connect to the network.
I cannot get my new Acer Aspire x1301 to find wy wireless network. I bought a Netgear wireless adapter, it seems that there may need to be a switch or something to turn the wireless on.
What os installed in your pc? try check hardware devices if wireless lan is properly installed by right clicking my computer dn properties and go to hardware tab then device manager. check netwrok adapter if there is a network wireless adapter installed. if not try installing your wireless adapter.
Wireless conection on off on off every 3 second
try the following separately each time:
1) Turn off the power off the router, turn off the PC, turn on the router, turn on the pc after a minute or two.
If this does not work, Try:
2) Remove the Wireless router Definition on your PC and reinstall it. Make sure that you are using the correct Passwords between the router and the PC.
1helpful
Internet setup
few things you can try:
1. check to make sure you're getting an IP address.
2. try reloading the wireless card driver.
3. is you wireless static or dynamic? If dynamic, try configuring it with static setting.
4. If this don't work, try the wireless card on a different slot.
5. if don't work, try on a different PC to see if wireless card is working or not.
It's possible you have a bad wireless card.
good luck!!
2answers
Two pcs running vista home edition wired to router ok. laptop wireless ok. advent pc running windows xp wireless cannot see belkin router but can see outher router in my area. router is a belkin N wireless...
Check the router settings, if the router is set to only use 802.11N wireless it won't pick up a computer that is using 802.11G or 802.11B wireless.
Good luck
Try to setup home wireless network to share two home computer
Connect the home wireless network router box to the main PC through an ethernet cable with the PC powered off and the home wireless router powered off, then power on the PC & the router. Vista should locate the new wireless network and follow the windows vista network setup procedures. After the wireless network has been detected you then while the second PC's power is shut off you connect dongle adapter to the PC power on and XP will locate the new adapter. You will probably have to enter your networks pin for the connection.
Get back to me when you complete these steps.
Try next time contacting me through an online chat session. We can resolve the issue quicker while chatting together.
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
