Woods Indoor 24 Hour Digital Timer (59203) Logo
Posted on Nov 28, 2010
HOW DO i SET THE WOODS 59203 TIMER LOST DIRECTIONS
A
Anonymous
Woods timers and manuals:
http://waterheatertimer.org/Woods-timers-and-manuals.html
The picture shown at fixya for 59203 is not correct.
Picture shows 49112 which is also TD1000:
Manual for 49112-TD1000:
http://waterheatertimer.org/pdf/Noma-TD1000.pdf
Manual for 59203:
http://waterheatertimer.org/pdf/Woods-59203.pdf
Manual shows 15 steps.
Plug timer in to charge battery. If battery will not charge, then timer is bad.
Set current time.
Set program1 ON time.
Set program1 OFF time
Set program2 ON time
Set program2 OFF time up to 20 pairs of ON-OFF times.
When programming is complete, press ON/OFF/Auto until Auto shows in display.
Add a comment of you need help with specific programming.
Instructions for programming a Woods #59203 timer
Woods, GE, and Intermatic have each made versions of this timer
http://waterheatertimer.org/Woods-timers-and-manuals.html#59203
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Lost instruction for operation of woods indoor digital 24 hour timer (59203)
1) Copy following link for possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Oval
2) Don't forget to reset timer to clear traces of prior programming.
Timer has internal rechargeable battery that eventually gives out, rendering timer useless.
Timer has 1 year limited warranty through Coleman.
3) Suggested replacement timer: Woods 59009, 59008, 59007.
Two prong and 3-prong outlets, rated for CFL LED incandescent etc
http://waterheatertimer.org/Woods-timers-and-manuals.html#50009
4) Or buy timer locally for ez return if timer does not work.
5) Jan 2013: Best brands for warranty support are probably Woods, Intermatic, GE, Tork, Sylvania, Leviton.
Promotional-grade timers from First Alert, Timex, Brinks, Stanley-Westinghouse, Utilitec etc may not have clear on-line warranty support.
We have lost the instructions on how to set our timer can you help or direct me to where we can get instructions?
You posted under a timer that looks like Woods 59203, GE 15091, and Intermatic DT300.
Each of these timers is made by Intermatic.
Open page to identify timer for sure:
Manual for timer:
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Purchased this timer (Woods Digital Timer Cat. No. 59203) this time last year to run my Christmas decorations. It work like a charm. Now setting up decorations this year and nothing shows on the display...
Woods 59203 manual:
If this is not your timer, add a comment or look through Woods page
Most of the plug-in digital-programmable timers have rechargeable battery.
Some have a AAA battery that is replaceable, but most do not.
59203 has rechargeable battery.
Battery is not replaceable.
Plug timer into wall for 1/2-1 hour.
If display does not show, then battery did not recharge.
Either timer is broken or wall outlet does not have electricity
1helpful
I lost the installation & how to program infomation.
Woods in-wall 59018 is programmable timer:
http://waterheatertimer.org/pdf/Woods-59018-59028.pdf
Woods 59203 plug-in timer is programmable:
Woods 59337 plug-in timer is programmable:
http://waterheatertimer.org/pdf/Woods-59377.pdf
Older style Woods 49556 plug-in timer is programmable:
http://waterheatertimer.org/pdf/Woods-49556-TD1300.pdf
If your timer is not listed, add a comment with description of timer
1helpful
Lost my manual and don't know how to set it up thanks
Plug timer into wall to charge battery.
If battery will not charge, then timer is no good.
Once battery is charged, remove timer from wall so you can program it.
The manual has a long list of steps to set timer.
If you have specific problems with the steps, add a comment and I will help.
I've lost the instruction manual to my woods model 59203 timer . How do i program it ?
Check following link to identify timer and download manual:
Industries 59377 Indoor Digital Timer 7-day: how do I set the on/off time on the 59203 timer...
Open link to identify timer for sure.
Each timer on page has manual
Top Woods Hardware & Accessories Experts
jdthefixer
vince
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
