Nokia N70 Cellular Phone Logo
Posted on Dec 02, 2010
Not enough memory delete some data! Nokia n70
Anonymous
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Dec 02, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
10
Questions
0
Helped
1731
Points
38
Nokia n70 has a one big problem it is having less internal memory so there is only one solution to it delete all the inbox messages and sent messages and drafts and some of ur games then try to delete some of ur photos and vedios from phone memory then it may fix ur problem and sorry for my english
My n70 mobile says not enough memory to perform.delete some data first,what to do?
format your memory,then reset your mobile,switch off your mobile and turn on
N70 cannot receive sms ,flashes new message icon & shows message. Not enough memory to perform operation .Delete some data first
go for factory settings reset. it will be restored to the condition in which it was shipped. remember to back-up your data before you try that.
Hy... I have a Nokia N70 Music With 1 GB RS-MMC. Now, i have a problem with the memory.. If i operate some aplication with my N70, notification log : Not enough memory to perform operation, delete some...
Dude, your nokia phone operates its internal applications using the phone's memory and not the memory of the 1 GB RS-MMC. Your phone memory is full of datas. Empty your phone memory datas and transfer them to the memory card, and keep your phone memory free EVERYTIME!
Aug 06, 2010 • Cameras
1helpful
Nokia N70.sms sned and recv problem showing delete some data
try to reformat your phone first turn off your phone and press hold * 3 call sign and turn on your phone you must hold press those key until your phone is reformatted
2helpful
2answers
Can not send or receive sms.though memory space is free 746Mb
Here "Not Enough Memory" Suggests either the SIM Memory is full or the Phone Memory is full. It has nothing to do with te Memory Card.
As you say there is only one SMS in the INBOX, I suggest you check the SIM Memory. It will be full. Delete some data from SIM memory. It shud work
5helpful
Memory low n70
You need to change default storage device on your phone, from phone memry to card memory. In other words, move all data (messages, songs, videos etc) from your phone memory to card memory.
for example, go to messages>options>other>momory in use - change it to memory card instead of phone. (if your memory card is not named, it will be displayed as NO NAME).
Do the same with other data also.
17helpful
6answers
Music Player: Not enough memory to perform operation delete some data first
nthing to worry change ur message setting ,put memory card memory as memory in use. after cahnging tht u cn easily save ur files to ur memory card
N70 issue
Ok first,transfer all your data to memory card using fexplore or file manager then check ur phone memory if it dont work try this 1. first type dis code *#7370# then press yes and then put your security code and it will format ur phone.
WARNING: remove ur memory card and try the second solution
and all data of phone memry will b erased
Top Nokia Cell Phones Experts
Kolbrun...
Sudeep Chatterjee
Sudeep Chatterjee
Rommel Balcita
