Zebra QL 420 Thermal Label Printer Logo
Posted on Dec 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I factory reset a QL420+ zebra printer?
Computer Links
Level 3:
  • Master 2,386 Answers
  • Posted on Dec 02, 2010
Computer Links
Master
Level 3:
Answers
2386
Questions
Helped
728090
Points
7718
Hello
Press and hold both the PAUSE key and FEED key while turning the printer power ON.
Release both keys anytime after the first front panel LED turns OFF.
The PAUSE and FEED keys together reset the printer to the default settings. These values
are not saved in EEPROM, but may be saved by sending the ZPL command ^JUS or
saving through the LCD on the deluxe front panel. After entering factory defaults, the
printer will remain in the paused state to let the operator know that the defaults have been
loaded.
good luck, do rate the solution if got help
Getting blank page feeding while printing with Zebra ql420plus....but it is working with MZ320
I have experienced similar issues between two zebras. I found that the driver was the issue. I recommend:
  1. Confirm the operating system your using. [32 or 64 bit is important]
  2. remove old driver and install new driver from Zebra's support website. https://www.zebra.com/us/en/support-downloads.html
  3. If you are still having issues after all that, I really must recommend contacting Zebra as your printer may be defective and may be under warranty for service or replacement.
Zebra 430T cannot reset to factory defaults
try with wwwseagullscientific.com drivers, this driver have the option to resset printer to factory default.
2 partial labels being printed on 1 label
most likely to do with sensor --- label has a notch in it it in middle make sure it is clean --- do labels have a hole that align with sensor?
Look at Cleaning printer to locate sensor
http://www.zebra.com/content/dam/zebra/manuals/en-us/printer/ql-qlp-qrg-en.pdf
1helpful
2answers
How to enable ZPL on a QL420 wifi printer
Include this command before the start of your ZPL code:
! U1 setvar "device.languages" "ZPL"
LABELS FOR ZM400
The labels for the ZM400 and the QL420 are not interchangeable.
1helpful
Zebra QL420 portable printer label gets misaligned frequently
There are two things to consider here: 1) Is the printer set to the correct media handling setting? Look in the manual for the terms BAR-SENSE and GAP-SENSE and make sure that you have sent the correct command to the printer. 2) There is a TOF or Top of Form setting that you can send to the printer to align the perforation of the labels with the tear bar. Look for the syntax in the manual, which is free for download at zebra.com, and make sure that your perfs line up with your tear bar.
Top Zebra Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
jdthefixer
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
