SOURCE: nissan murano 2005 sl keyless entry remote programing
Close all vehicle doors, LOCK doors using drivers side switch.
Insert key all the way into the ignition, (do not turn) remove key.
Repeat this step 5 times. (6 total)
Hazards should flash to indicate program mode.
Press any button on transmitter to be programmed, hazards should flash to indicate successfull program.
*For additional remotes, cycle drivers door lock UNLOCK, LOCK, press
any button on remote, hazards should flash. Repeat step as necessary.
Ignition ON, (engine off) ignition OFF, UNLOCK using drivers side switch, test remotes.
Source
SOURCE: program remote keyless entry
1) Turn key from OFF to ON eight times within 10 seconds ending in the ON position.
2) After doors lock then unlock, press any button on the
remote being programmed.
3) The doors should lock/unlock to confirm programming.
4) Turn key to OFF and door locks should cycle one last time.
SOURCE: Program keyless remote entry
I need a year, but u can look it up at the link provided below.
http://www.programyourremote.com/
SOURCE: How to program keyless remote
I just had to buy one too and these are the instructions I was given by the guy I bought it from. I haven't tried them yet. Hopefully they work for us both :).
1.Find the ETACS unit under the steering wheel first,there is a small switch onit.
2.Once the switch is located make sure your key is not in the ignition and set the switch from off to set.
3.Press keyfobs door lock button for one second, this sends the codes to the ETACS and stores it.
4.Do the same thing if you have 2 remotes for the vehile.
5.Now set the ETACS switch from set to off.
6.Remotes should now be programed.
SOURCE: 2006 chevy equinox keyless remote programming
from the service manual:
There is no onboard programming procedure for this vehicle. This vehicle requires special equipment be connected to the vehicle to program the keyless remote. Please go to the nearest GM dealer for assistance
