These are great systems:
Go into "MENU" (MENU BUTTON)
Scroll down until you see "MENU/HELP"
Scroll down to "PROGRAMS" - HIT "SELECT" when you find "PROGRAMS"
It will say "PROGRAM 1 of 1" that is what you want - Hit enter
- This will tell you what time the program is set to run
If there is more than one program, You will see "PROGRAM 1 of 2" or however many programs you have programmed.
If you need to delete a program, go to the program you are looking to delete, it will ask you if you wish to delete the program and you will use the up and down arrow on the panel.
It is really that simpe!
For deletion of all programs (factory default). There is a SMALL reset button. The lights will go out and then light up. Will light up to the left and then to the right. Resetting this will erase all run times back to factory default. You will not loose your programs (memory of knowing what system it is) it just resets the times to factory default (1200 Military times).
***IF YOU HAVE A COMPLICATED PLUMBING SYSTEM WITH SEVERAL RUN TIMES - DO NOT DO THIS!**
If you are looking to just erase additional run times and only need the one run time (for circulation) this might be the better option to resetting and erase all run times and reset back to a basic 1 of 1 run time.
