Garden Logo
A
Anonymous Posted on Dec 15, 2010
How do you set a stanley item 58487 outdoor timer
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 04, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4408
Points
I had the same problem and found no help online. Finally located the manual. Here's what is says:
Plug timer into power outlet. "C" will appear on the Digital LED.
Set current time: press the "TIME" button repeatedly to set the current hour. The dot at the bottom right of the Digital LED will appear to indicate PM hours.
Set off time: press the "OFF" button repeatedly to set the OFF hour.
Press the "TIME" button to complete the programming. Timer is now set to turn the plugged-in devices ON at dusk and OFF at the time you set.
  • 1 more comment
  • Shirley Scharf
    Shirley Scharf Dec 02, 2014
    This worked. Thanks for the information
  • Judith Nelson
    Judith Nelson Dec 13, 2017
    THANK YOU SO MUCH KEVIN NOLAND, YOUR A GOOD GUY.
  • Ankit Saini
    Ankit Saini Mar 03, 2018
    This is the formula where you can receive the the information of the game which you can play http://spidersolitaire.me online because this is too much funny spider solitaire online free.
Brightrs
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Posted on Nov 28, 2024
Brightrs
Contributor
Level 1:
Welcome Back:
Answers
Questions
0
Helped
4408
Points
Thanks for the helpful post! I just bought the Stanley 58487 outdoor timer, and I was struggling a bit with the setup. Your instructions made it so much easier to understand! One tip I'd add is to make sure the timer is plugged into a grounded outlet for safety, especially if you're using it for outdoor lights or decorations. Other than that, the process was straightforward once I knew where to set the current time and how to adjust the on/off cycles. Appreciate the guidance! Brightrs
Top Garden Experts
ADMIN Andrew
ADMIN Andrew
john h
CJ Rock
CJ Rock
