Compaq Presario M2000 Notebook Logo
Posted on Dec 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I do have a problem with my presario M2000 Compaq laptop which whenever i open the laptop, it keep asking me password. Futhermore, my dvd rome cannot response to cd. can u help me. Tq
Anonymous
Level 2:
  • Expert 314 Answers
  • Posted on Dec 24, 2010
Anonymous
Expert
Level 2:
Answers
314
Questions
0
Helped
96161
Points
909
  1. Disconnect the power cable and any printers, monitors or other peripherals you may have attached your M2000. Lay the laptop face down on a table, with the front of the laptop facing you. Remove the battery by sliding the release latch to the left. The front end of the battery will pop up. Rotate the battery toward the back of the laptop to disengage it from the laptop base.
  2. Locate the hard drive on the right side of the laptop. Remove the two screws holding the hard drive cover in place and remove the cover. The hard drive will have a mylar tab on it to help remove it. Grab the tab and lift up on the left side of the hard drive until it disconnects from the motherboard. Pull the hard drive straight up to remove it from the hard drive bay.
  3. Remove the single screw holding the optical drive in place. Stick the end of a bent paper clip into the disk tray release hole on the optical drive, located on the front of the disk tray. This will eject the disk tray. Grab the tray and slide the optical drive out of the laptop base.
  4. Remove the memory modules. The memory compartment is located in the center of the M2000. Remove the two screws holding the cover in place and remove the cover. Use your fingers to spread the latches on the sides of the memory modules and slide the modules out of the sockets.
  5. Remove the mini PCI card by first removing the last cover on the bottom of the M2000. Remove the screws on the cover and remove the cover to reveal the mini PCI card. Disconnect the white and black wireless antenna cables from the card. Spread the latches on the sides of the card and slide it out of the socket. Disconnect the antenna cables from the clip attaching them to the laptop base.
  6. Remove the keyboard cover and LED board by first removing the two screws in the battery bay. These hold the keyboard cover in place. Flip your laptop over and open it up. Slide a flat-head screwdriver into the notch behind the "F1" key to unlock the keyboard cover. Do the same thing at the "F5," F11," and "Insert" keys. Pull the cover up to remove it. The LED board is under the cover. Disconnect the data cable from the motherboard and remove the two screws holding the board in place. Remove the board.
  7. Remove the keyboard by first removing the four screws holding the keyboard in place. Lift the back end of the keyboard up and tip it over so it is resting face down on the palm rest of your M2000. Disconnect the data cable from the motherboard and remove the keyboard.
  8. 8 Remove the display panel by first disconnecting the video cable from the motherboard. Disconnect the wireless antenna cables from the clips attaching them to the top cover of your laptop. Remove the six screws holding the display panel in place. Lift the display panel off of the laptop base.
  9. Remove the base enclosure by removing the three screws on the top of the laptop connecting the top to the base enclosure. Flip the laptop over and lay it face down with the front toward you. Remove the 18 screws holding the base enclosure in place. Lift the rear end of the base enclosure up until it comes free from the laptop. Once it's free, slide it back to remove it.
  10. Disconnect and remove any remaining components including the speakers, Bluetooth module and USB card. All of them are removed by the same procedure. Disconnect the cables from the motherboard and remove any screws holding the components in place. Lift the components straight up to remove them.
  11. Disconnect the fan cable running from the cooling unit to the motherboard. Remove the three screws holding the cooling unit in place and lift it straight up to remove it. To remove the CPU, turn the locking screw counter-clockwise until it clicks. Grab the CPU by the edges and lift it straight up. Put the CPU in an antistatic bag for safekeeping.
  12. Remove the motherboard by first disconnecting the touchpad cable and remove the five screws holding the motherboard in place. Lift it up by the left side and remove it from the enclosure.
  13. please comment on these solution by saying how helpful.rating or voting.
Muntejaya Ginting
Level 3:
  • Master 10,422 Answers
Muntejaya Ginting
Master
Level 3:
Answers
10422
Questions
Helped
2520764
Points
19566
HI,
Your compaq is and password protected and need to disable if you want to do so. It could BIOS password or OS password.
You CD rom should give response while you insert the CD. The indicator light should blinking and motor should turning. Further more you may broken lens, wires problem.
You need to check to find where does the problem lies and take necessary action to get them fixed.
Regards,
Jay
Top Compaq Computers & Internet Experts
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Frank Fernandez
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
