Paper jammed, I cleared the jam and now when I turn the power on the blades won't turn. You hear the motor but no movement.
Well, despite the manufacters warning label I choose to take the shredder apart and found that one of the plastic gears was broken. Hence the motor runs, but the blades do not turn. The thing I didn't understand, the there are metal gears and plasic gears...I can only imagine that the plastic gears at one point or another are going to give. I would suggest not to void the manufacters warrenty, take the shredder back, and get one that is built a little stronger. Hope that helps.
Same thing: paper jammed, removed and cleared the jam, and now the motor runs, but the blades don't turn. Either on or in reverse, either way.
Thanks,
bzb
The overheated light came on I let it sit overnight and the motor comes on and does not shread?
My SPL-1506X shredder was making motor noise but the blades wouldn't turn. I disassembled the head and found that the smaller of the two nylon gears is severely stripped. I've been going crazy trying to find a place to buy a replacement gear. It's easy enough to fix, I just can't find it.
I have the same problem with that staples shredder. I called Staples products department. They told me they could not sell me the plastic gears because it was a "liability issue." I really think that they purposely put the plastic gear up against the metal gears so that you would have to either buy their "warranty" or purchase a new shredder every couple of years. I'm going to see if I can get a new metal gear machined.
