Pinnacle Studio Version 9 for PC Logo
Posted on Jul 07, 2008
Runtime error i have trouble opening my pinnacle 9 se, i keep gettin a (microsoft visual c++ runtime library)-- runtime error-- abnormal program termination) and then program closes, how can i fix this problem thank you
  • landiefixya Jul 11, 2008
    Re: microsoft visual c++ runtime error
    hi i found an easy simple way to fix: (microsoft visualc++ runtime error), what i did, i created a new user name and password. then after i did this i opend on pinnacle studio icon i right clicked on program and opened the program RUN AS
    once opened RUN AS.. will ask you: which user account do you want to run the program?
    you should DISABLE (UNMARK) the: protect my computer and data from unautorizes program activity. Disable ONLY for pinnacle program. next you can keep you account or change user. click ok an problem solved.
    I had endless nights with my pinnacle program i just start to render and after couple hours i get runtime error, but since i have used it this way, my program working proply, my sound used to start and just go away, but since doing this,everything working. made 2 dvd"s today.
    good luck and hope this works for you as it has for me
    bye
  • totallyradd Aug 08, 2008
    I'm having the same problem with the runtime error and I did what you said but it didn't work!
    I made a seperate account and everything and unchecked the protected thinggg and it still didnt work.
    Whenever I try to click "make movie"
    that message comes up.
    or even if I'm just saving and then when I close the program, it comes up then too.
    helllp!
5 Related Answers
Anonymous
  • 64 Answers
  • Posted on Jan 29, 2009
SOURCE: I have a message that I cannot close which sayes
which operating system? in XP you can try to hit start menu, click on ALL Programs, then click on Startup folder if you see the window listed in that folder you can right click on it then choose delete from the pop down menu that opens. After that reboot and see if it.s gone bye, bye. Please rate this answer if it helps.
Anonymous
  • Posted on Apr 21, 2009
SOURCE: picture it 2002 terminates when trying to open a project
Hi all!!! I am soooo excited!! I found a solution to fix the abnormal program termination with my picture it 2002!!!! Many, many thanks to John Inzer who made this info available!! I am no computer expert, but persistence and research paid off! My software is now up and running!!!! Click on the link below: microsoft.com/downloads....etc.
The best part is that it doesn't cost anything!!
Eve
Albirt wrote:
> Hi. I am having same problems with picture it.
> "Runtime error / abnormal program termination" message when I try to
> open picture.
> Windows XP and Picture It 2002 Photo.
> Could you reload file to yousendit ?
> Thanks
No problem....try the following link:
http://www.yousendit.com/download/UmNLcmxTSWVrWS92Wmc9PQ
The patch is also available from
Microsoft Download Center:
Picture It! Publishing 2002:
Patch for 19299 (PI19299.exe)
http://tinyurl.com/dfeq28
or...
http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=0fb68178-d6bd-41bd-9f00-f44ac7ca9e28
Anonymous
  • 50 Answers
  • Posted on Jan 19, 2010
SOURCE: Cannot install Pinnacle Studio 12 Video editting
Make sure to back up the registry before modifying it. For more information about the registry, refer to your Windows documentation or contact Microsoft.
  1. Choose Start > Run.
  2. In the Open box type Regedit and click OK.
  3. Browse to the following keys:
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
  4. Verify the drive, path, or variables are valid for each of the keys.
    For each of these keys on the right hand side there is a Data column. Each entry that refers to a variable or a path name - each value needs to refer to a valid drive, path or variable. These path names may be unique to your individual PC - to restore the defaults it may be necessary to examine a known working machine, or contact a Microsoft Windows technician for additional help.
Anonymous
  • Posted on Feb 11, 2010
SOURCE: Microsoft Visual C + + Runtime Error
I just recently install Window 7 ultimate on my computer and then Acrobat 8 Pro start acting up. Try to open PDF file it will open for a little while then this thing pop up said Microsoft visual C++ Runtime Library and Runtime Error. Then it shut down.
Anyone know how to solve this problems please help.
Karoon Yip
karoon.yip@gmail.com
elix0411
Jose Cada
  • 3530 Answers
  • Posted on Jul 18, 2011
SOURCE: unable to download pinnacle studio
Welcome to Fixya
Authorization request could be your card infromation. May i know the site you are trying to download this program.
Your response will be greatly appreciated.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Top Pinnacle Computers & Internet Experts
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
