The RAID driver was supposed to be created by the Gigabyte CD on to a floppy disk. Durring windows you were to incert the floppy disk & press F6. Windows would have included the driver software. You can also go to Gigabytes web site & download the RAID driver. (This site is for rev 2.0).
http://www.gigabyte.com.tw/Support/Motherboard/Driver_Model.aspx?ProductID=2422
For help instruction on how to setup a RAID configuration. Read through this link.
http://www.pcstats.com/articleview.cfm?articleid=830&page=6
& this link will also help.
http://www.pctechguide.com/tutorials/RAID.htm.
Read pages 65 to 75 for RAID setup in manual.
The links online will help you understand setting up a RAID system.
Good Luck! & Take you're time.
Mike
SOURCE: ? Cannot tell if this motherboard has a raid controller
this motherboard has raid support...check with the bios settings
you can get raid drivers straight from foxconn
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=946GZ7MA-8KRS2H&TypeID=en-us0000004
nb choose the correct model
SOURCE: How to disable raid feature
For starters you read your Instruction Manual or User Guide and you will find it there. If you have no manual, you will need to go to our sales department and buy one. CONSTANTIN (arzconst)
SOURCE: install a second sata hdd to a gigabyte ga-p35-ds3
ther is no need for a raid array. connect hdd assign priority to the new hdd. install 7 on new hdd,
or
just connect hdd , boot to xp , put windows 7 dvd , instal it on new hdd while u r in xp
if ur new hdd is not detecting just clear c-mos settings
Jai
SOURCE: what cpu is compatible with motherboard GIGABYTE
Go to http://www.gigabyte.com/support-downloads/download-center.aspx?kw=GA-965P-DS3
and click on revision 1.0 - 3.3 as there may be additional CPUs supported in Rev 3.3 vs 1.0, you have to determine what specific Revision you have.
