Bosch Nexxt 300 Series WFMC2201UC Logo
Posted on Jan 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code 13 - Bosch Nexxt 300 Series WFMC2201UC
Anonymous
Level 3:
  • Bosch Master 2,605 Answers
  • Posted on Jan 02, 2011
Anonymous
Bosch Master
Level 3:
Answers
2605
Questions
0
Helped
1133016
Points
11111
Welcome to FixYa.
The E13 error code on the WFMC series Bosch washer`s refer to a drainage problem, as you may or may not already know. ( or in Bosch terms "pump time exceeded" )
Anyway, here`s the most likely way to remedy a E13 code.
**Unplug the washer from the wall or turn off the breaker before attempting any repairs**
Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water, that sucks...hopefully you won't get too wet. ( maybe you`re lucky enough to be close to a floor drain )
  1. Locate the round door on the front of the machine (about 6" in diameter, lower right corner) Error code 13 - macmarkus_26.jpg
  2. Find a drill bit or small screwdriver that fits in the hole in the round door.
3. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful).
4. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand. ( you should also see a red ring with a string attached, if you pull this the door should unlatch, but getting the water out first is usually a good plan )
There is a small collector lip at the bottom of the cap, that is where you can hold the wet/dry vac to catch the water. Unscrew slowly so you don't get flooded, until it is unscrewed all the way out
5. Now pull out the trap and visually inspect the inside of the pump as well as the filter/trap. Hopefully you'll find the item/debris that initiated the error code.macmarkus_28.jpg
6. After removing any debris or obstruction`s re-install the button trap/lint filter and plug the washer in to power or reset the breaker and give it a test.
7. Run a load and watch for leaks. Leave the pump access door off until you are sure you screwed the cap in tight and there are no leaks.
Ultimately you may have a faulty drain pump, but I would certainly start by performing the things I listed first.
Let me know if you require further assistance and if not and this solves your problem, please rate the solution I provided accordingly.
Thank you for coming to "FixYa" and good luck.
Regards,
Macmarkus :)
  • 2 more comments
  • Anonymous Nov 01, 2011
    do you have a copy of the service manual so I can replace the pump. Thanks Bobbie
  • Jackie Jaffe
    Jackie Jaffe Apr 02, 2014
    This was awesome help. I was able to avoid a service call. It was very quick to do, minus all the cleanup of water and gunk. I have a Vision Series 500, but it was almost the same.... Thank you!!!
  • Heather Brown Dec 08, 2015
    Cannot thank you enough! No idea how the hook part of a plastic hanger got in there (and it fits perfectly-tweezers were needed to get it out!), but it is out now, and all is right with the world. You saved the holidays!
  • William Werner
    William Werner Feb 20, 2017
    I followed Mark's instructions 1-3 and then I used my wet vac to vacuum the water out through the drain hose. After removing 2 gallon of water I completed steps 4-7 as Mark instructed. No more than an ounce of water wet the floor. Thanks Mark for the procedure.
Top Bosch Washing Machines Experts
Sudeep Chatterjee
Sudeep Chatterjee
vince
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
