Televison & Video Logo
Posted on Jan 02, 2011
Remote programming code for a Viore RPT50V24DX/SMS
5 Related Answers
Anonymous
  • Posted on Aug 25, 2008
SOURCE: Code request
HT3061P
bigguy196
  • 6 Answers
  • Posted on Apr 20, 2009
SOURCE: Viore Remote Control Codes for Direct TV
Contact service provider ( ie Directv.) to see if they have the code or a scanning method to get it to work.
jairo sanchez
  • 276 Answers
  • Posted on Aug 26, 2009
SOURCE: TV turns off after a few minutes.
eso es mala configuracin de su tv revise el manual de usuario
Anonymous
  • Posted on Mar 29, 2010
SOURCE: I have a Viore RPT50V24DX/SMS TV, That just turns
A: Check clearances for proper ventilation, as overheating can occur even with the fans running. B: If A checks out then replace the lamp as it is in failure mode. They do not usually just all of a sudden fail. They give symptoms such as this.
Anonymous
  • 3 Answers
  • Posted on Jun 10, 2010
SOURCE: Viore model:RPT50V24DX/SMS shuts off and LAMP light blinks
Turn your set around. Locate the square access panel located on the lower right. Remove the 4 screws. Remove panel. Then push down tab on cooling box, it will look similar to a horn. Lift and remove. Lamp will be visible towards the back. Locate the pull handle,it is made of strong wire and it will be folded sideways. Pull open the handle. Look for screw on the left side of the lamp. It secures the lamp in place. Remove the screw completely. Now pull the handle firmly and voila! The lamp will slide out. To install new lamp just reverse the process. NOTE!!! Do not touch the lamp with bare hands. It will damage it. Wear surgical gloves or handle with a cotton cloth...
Top Televison & Video Experts
ADMIN Andrew
ADMIN Andrew
Larry
ADMIN Eric
ADMIN Eric
