SOURCE: acer aspire 5630 -built in webcam doesnt work
My acer aspire webcam has stoped working pc doesnt recognise it
SOURCE: HP 2133 mini-note PC webcam stopped working!! Help!! PLEASE!! :((
In your control panel you can select system properties and then device manager.
If the webcam had a yellow ! then you will need to install or update the drivers. Drivers can be found under the support section at the manufactures website.
(easy way to system properties is windows key + break key)
SOURCE: inverted picture on yahoo messenger
under c:\windows\bisoncam there is a program that will allow u to change this.
SOURCE: Toshiba built in web cam not working
Remove both Webcam driver and skype with a software called Vista Manager from yamicsoft.
Why a third party tools to uninstalled a software?The answer is it will remove even the files or registry key that is concern with that software.
Download the file using the link below
http://www.yamicsoft.com/vistamanager/software/vistamanager.exe
If you are with windows 7 then downalod Windows 7 Manager
Here is the link :
http://yamicsoft.com/windows7manager/software/windows7manager.exe
after unstalling reboot your system.
First installed your webcam driver and check webcam work or not. Then installed skype software.
It will work.
Note: Lastest skype version have problem with webcam synchronisation.so used a little older version.
SOURCE: Acer Crystal Eye webcam.. image inverted
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
armania19
