Sta Rite Sta - Rite Duraglas In - Ground Pool Pump - 1.5 Hp Logo
Anonymous Posted on Jan 04, 2011
Where can a find a new pump CHEAP? Current pump is Model C48L2P104 (18 years old). Serial 1B93. Voltage 230 HP 1.5 RPM 3450/1725 Amps 9.2/2.5 Frame 48Y Dura-glas H/L
John Prohaska
Level 3:
President:
  • Sta Rite Master 1,378 Answers
  • Posted on Jan 04, 2011
John Prohaska
Sta Rite Master
Level 3:
President:
Answers
1378
Questions
Helped
698779
Points
3511
A new motor and pump parts (if needed) would be cheaper than a whole new pump. Your motor is part number UQS1152R or if you just want a single, high speed motor you could use USQ1152 to replace it. You will likely need a seal and seal insert as well; part number 100 (it may have letters in front like AS100, PS100, etc) and J3-2. A whole new pump you should shop for part #P2RA5YF-182L.
For a quote on the parts from us you can contact us using thru our website at www.arrowpools.net. Otherwise, google those numbers to locate your best deal.
John
  • Jay Finke
    Jay Finke Jan 05, 2011
    THIS IS THE BEST PUMP YOU CAN HAVE, NO MATTER HOW OLD. THE BEST THING TO DO IS SEARCH YOU ZIP CODE FOUR YOUR LOCAL POOL MOTOR REPAIR, HAVE HIM REBUILD YOUR MOTOR OR SET YOU UP WITH A REBUILT MOTOR.. $75-85 WITH A FREE SHAFT SEAL. THIS PUMP OF YOURS MAY TAKE THE 100 OR THE 200 SHAFT SEAL. IT ALSO MAY NEED A NEW DIFFUSER THERE ABOUT $20. HOWS THAT FOR CHEAP ? PRIME YOUR PUMP AFTER ANY REPAIR , AND WATCH FOR WET SPOT .. JAY
Top Sta Rite Pool & Spa Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
