SOURCE: toshiba satellite p20, pxe-e61, pxe-mof
cable plug possible defective, if possible plug into another computer and see if error occurs. since you did not state OS go into the Device Manager and insure 'network adapter' has driver installed and working. Is there an external media hooked up?
SOURCE: ACER 5315 IS DEAD ON BOOT UP IT DISLAYS
Sounds like it is trying to boot from network drive. Have you changed the bios boot order. If so, change it back to boot from hard drive first.
SOURCE: PXE-E61,PXE-MOF,OPERATION SYS MISSING
I have three kids with the same Acer Aspire 3680-2681. All in over a year have had this. The first sat til we gave up and just tore apart. Put back together, it worked, better. Nothing done. The second, a couple months later, we just took out the hard drive, made sure it was in the correct and full way in, and it worked. This week, the third, same problem, same solution, Took out the hard drive, put it back in snuggly and it worked. It has two screws that SEEM to hold it in place but it does slip out. BEFORE you do all these other ms-dos things and other crazy time consuming file losing pictures forever gone things, try this, and bring a can of compressed air, get the dog hair and dust out while you are there.
It seems to be a small engineering thing with the screw placement and holding of the thing securely in my humble opinion.
SOURCE: aspire 3682 PXE-E61:Media test failure.check
PXE error means that it is trying to boot from an ethernet / lan connection.
check your boot order options first and set it to boot
1. Hard drive
2. CD rom drive
3. Floppy (or usb if you know how to do this)
4. network(aka PXE)
If it still fails then yes there MAY be an issue with your hard drive.
Check all hard drive connections before running off for a new one.
This can be especially true with SATA type drives most of which dont have any sort of true locking device to hold the connections secure.
Testimonial: "I found an internal disconectet cabel fixing it solved the bootproblem"
SOURCE: operating system not found
might there be a non system disk in a drive???
Check that before you do anything else.
Let me know what you find
thanks
a
