Hello!
Changing the Drum does not affect the scanner settings.
You can print because your PC (computer) can see your machine but for scanner is the oposit. The machine must see your PC.
I think that in this machine you have an SD card with the scanner funtion. Try to take it off and then put it on again. (the SD card is on its side. In the controller box)
You need to have a high funtion scanner to do this, But there's a problem with the 4wd. system that's causing the light to come on. The same scanner will be able to read the codes.
I have that problem a lot with this model. Unless it's 'sticking' which would mean its dirty... this in my opinion needs to be repaired. That is what i always do in this case.
absolutely not, (MS) it could be for many reasons like incompatible drivers, incompatible OS, mind you if you can double check the right OS platform you have downloaded and the right bit as well, (32 or 64), XP or Vista, can you double check pls, these are some reson why it become too slow
you might want to check on uninstalling this again
