Philips 60PP9753 60" Rear Projection Television Logo
A
Anonymous Posted on Jan 12, 2011
Hi there - I've got a Phillips mdl # 60PP9753/17 and recently the picture has dulled and has a red tint . I'd consider doing minor repairs (less than $200.00 usd) if replacement parts can be aquired for less than said amount . I just don't want nor can I afford much more at this time . I've read something about the fluids needing replenished is that actually in the bulbs or bulb housing and/or is this a possible issue ? Best Regards and Good Karma , Jason
Anonymous
Level 3:
  • Philips Master 3,459 Answers
  • Posted on Jan 13, 2011
Anonymous
Philips Master
Level 3:
Answers
3459
Questions
5
Helped
866250
Points
5558
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
Hi there - I've got - 578ba6c.jpguploads/images/578ba6c.jpg" alt="578ba6c.jpg" class="h_mi" />
TV set after flHi there - I've got - 65af323.jpgbr />
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Top Philips Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
