Woods Industries 59377 Indoor Digital Timer 7-day Logo
Posted on Jan 18, 2011
How to set it to 12 hours on 12 hours off - Woods Industries 59377 Indoor Digital Timer 7-day
A
Anonymous
You posted under Woods 59377 timer.
Open following page to identify timer for sure:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
Manual appears below
http://waterheatertimer.org/pdf/Woods-59377.pdf
1) When programming, you can set 8 programs with choices of different blocks of days.
In your case, you want 1 program (Prog1) for all days of the week: So when selecting days, you want MON, TUES, WED, THURS, FRI, SAT, SU to display
2) When programming, you first set Prog1 ON, and then select all days as shown above, then set hour for 12am, and then set minute for 00.
3) Secondly you set Prog2 OFF, and then select all days as shown above, then set hour for 12pm, and then set minute for 00.
4) If 12am and 12pm do not display for some reason, then set times for 11:59am and 11:59pm.
5) Programming steps:
-Press PROG button until 1 and ON display. This is Prog1 ON.
-Press DAY button to select days
-Press Hour button to set hour
-Press MIN button to set minute
-Prog1 ON is set
-Press PROG button until 1 and OFF display. This is Prog1 OFF.
-Press PROG button to validate settings
-Prog1 OFF is set
-Press CLOCK button to return to current time
6) Manual shows other features
7) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
How do i reset the 24-hour time to 12-hour time on a Brookstone alarm clock
Dozens of models to choose from. All questions on Fixya need 'make model (what it is)' as the first 3 words.
Here are some guesses. The 'control cover' is where you put the back-up battery.
To change the 12/24 hour time format, open the CONTROL COMPARTMENT COVER on the bottom of the clock and adjust the 12/24 TIME FORMAT switch to the desired format .
Self-Setting Clock - Brookstone
Instruction Manual - Brookstone
Brookstone https://manuals.brookstone.com > ... PDF 12/24 HOURS TIME DISPLAY SETTING 1. The "12h" or "24h" will start flashing in LCD2 (Default setting 12h). People also ask
How do you convert a 24-hour clock to a 12-hour clock?"); display: inline-block; height: 24px; width: 24px;"> How do I change my alarm clock to 24-hour clock?"); display: inline-block; height: 24px; width: 24px;"> What is 12.30 pm in 24-hour time?"); display: inline-block; height: 24px; width: 24px;"> Feedback
Setting The 12/24 Time Format; Setting The Daylight Savings ...
ManualsLib https://www.manualslib.com > ... > User manual
Brookstone TIMESMART Self-Setting Clock Radio Manual Online: setting the 12/24 time format, Setting The Daylight Savings Time. The 12 Hour Format Is Set As ...
How do I change my Brookstone 399923 clock from military (24 hour) time to standard (12 hour) time please?
Try this
Setting the 12/24 time format The 12 hour format is set as the default. To change the 12/24 hour time format, open the CONTROL COMPARTMENT COVER on the bottom of the clock and adjust the 12/24 TIME FORMAT switch to the desired format. Close the CONTROL COMPARTMENT COVER.
I just bought whirlpool microwave model wmh32519hz, I can't figure out how to set clock, it has no start button I'm stumped and can't find anything on google
The clock is a 12-hour (12:00-11:59) or 24-hour (0:00-23:59) clock. Touch OPTIONS/CLOCK to reach clock submenu, and follow the prompts to set the clock. Clock format (12 hours with AM and PM, 12 hours without AM
Steel Leopard Shark watch manual
To set the hour format, press S1 button
to toggle between 12-hour and 24-hour
format. The P.M. indicator may be
displayed to indicate the time period
12:00 A.M. - 11:59 P.M. in 12-hour
format.
11.To set the calendar format, press S1
button to toggle between M-D (monthdate)
and D-M (date-month) format.
12.After finished making all the settings,
press S2 button to confirm...
Dec 25, 2013 • Watches
How do i set it for 12 hours on and 12 hours off? No real problems, I just bought used without manual.
Hi sorry to ask this but "what" is the object or item that you need to set for 12 hours on & 12 off?
Mar 06, 2011 • Garden
2helpful
2answers
Somehow the clock is displaying 24 hour time format. I want to get back to 12 hour format. How?
Push the mode button twice to enter the "set time" mode. Once the digital display is blinking, keep pushing "mode" until the PM display section in the upper left corner comes on. Once that happens you are back to the 12 hour clock. To set the clock, use the 1-4 buttons to set the hours and minutes.
Hope this helps.
2helpful
2answers
The digital clock seems to be set to 24 hr insted of 12 hr time
No Problem here ya go
To change the clock to 24-hour format:
1. Press and hold the CANCEL and Delay
pads for three seconds.
2. Press the More+ or Less - pad to select
12 or 24 hour.
1helpful
2answers
12 hour vs 24 hour read on clock
Push the "mode" button twice to enter the time change function. Once the display is blinking keep pushing the mode button until you see the "pm" icon on the LCD display. When that happens set the clock as you normally would using the 1-4 keys.
Remember to check if the 12 hour clock is set to AM or PM.
Good luck.
9helpful
2answers
Aquatech watch
press mode button 3 times untill you get into the time set mode - press lap/reset twice until the hours start to blink.
press start/stop and cycle thru all the modes depending what time you want to set - it will go thru 1, 2, 3, etc thru 24 H then 1, 2, 3, etc thru 12 A then 1, 2, 3, etc thru 12 P - depending on thte time you want to set the A is for AM and the P is for PM
hope this helps
jeff
Jul 23, 2008 • Watches
Top Woods Hardware & Accessories Experts
jdthefixer
vince
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
