Electrical Supplies Logo
Posted on Oct 12, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
There have been problems with the Zinsco circuit breaders. I understand that Connecticut Electric has just used the information from Zinsco and therefore is likely subject to the same problems. Is the Zinsco GTE-Sylvania UBIZ2100 Circuit Breaker version any better or different than the Connecticut Electric version or are they all made the same way?
Steve Pack
Level 3:
  • Connecticut ... Master 7,214 Answers
  • Posted on Oct 14, 2017
Steve Pack
Level 3:
Answers
7214
Questions
Helped
2363380
Points
28837
The same. The problem is usually the box buss baars/
5 Related Answers
Jimster
James Greene
  • 240 Answers
  • Posted on Feb 02, 2008
SOURCE: whirlpool electric dryer keeps tripping main circuit breaker
First off, be sure the pigtail is wired correctly to the back of the unit. Black and red to the outside terminals, white to the middle, green to the frame or cabinet (should be a green screw close-by). If that is ok, you probably have an issue with possibly a bad pigtail, bad outlet, wiring issue, or possibly a bad circuit breaker or breaker box. Probably going to be more of a electrical problem than a appliance problem. Good Luck!!!!
Anonymous
  • 44 Answers
  • Posted on Mar 24, 2009
SOURCE: I have a home built in the 50's. circuit breakers
You need to put in what we call a sub box. This should be done by a licensed electrician, but if you really want to do it yourself you will need a distribution box some wire and it has to be connected directly to your main lags from the meter box, this box will have a main breaker built into it and spaces for additional breakers, depending on your existing wiring the electrician might chose to wire the additional box directly to your meter base and not your existing box. Either way you really should seek local professional help on this project, just for your safety and to satisfy your home-owners insurance.
Have a great day..
Tim
mydogisk
Kenneth
  • 50 Answers
  • Posted on Apr 10, 2009
SOURCE: I need a new 15 amp breaker and can not find Sylvania
Since Sylvania changed to Chanllenger later own, there are only a few options, " hope depo" may have a replacement breakers, but Cutler Hammer "BR" style should work. If they won't fit i would call the oldest electrician in town and see if he has a few in the van!
Anonymous
  • Posted on Jul 14, 2009
SOURCE: Remington electric tiller circuit breaker goes off
For about $20.00 you can buy 50 feet of 12 guage 3 wire yellow extention cord. You will then get all the amps you need to run your unit. If it still fails, you have a problem inside the tiller.
Tom MN
Anonymous
  • 1489 Answers
  • Posted on Aug 20, 2009
SOURCE: electric lawn mower repeatedly trips house circuit breaker
The breaker is tripping because there is a short in the mower electrical circuit -- most likely in the motor winding -- it overheated.
If you have a multimeter measure the resistance (ohms) of the motor winding by putting the meter probes on the two flat prongs of the power cord with the mower switch on. If you get near zero ohms, the winding is shorted -- motor "burned up".
Using the multimeter again, check for continuity between the round ground pin on the power cord and each of the two flat prongs. If you get continuity on either of these, there is a short to the mower chassis. This can probably be corrected without much expense.
My bet is on the motor winding being shorted.
Charlie
Top Connecticut Electric Electrical Supplies Experts
Steve Pack
Steve Pack
Anonymous
Are you a Connecticut Electric Electrical Supply Expert? Answer questions, earn points and help others
