HP LaserJet P3005n Printer Logo
Posted on Jan 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code 52.0 - HP LaserJet P3005n Printer
Nikolay Boychev
Level 3:
  • Master 525 Answers
  • Posted on Jan 29, 2011
Nikolay Boychev
Master
Level 3:
Answers
525
Questions
Helped
319111
Points
1298
A laser/scanner error has occurred
Recommended action:
1. From the DIAGNOSTICS menu, run the
laser/scanner motor component test.
Verify that you can hear the motor
rotate.
2. If you cannot hear the motor rotate,
verify that connector J1702 and J1505
are fully seated on the DC controller
PCA (ECU).
3. Verify that the connector J12 on the
laser/scanner assembly is securely
attached.
4. If the error persists, replace the laser/
scanner assembly
How do you replace the scanner cover oh the hp fax machine model 920
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS 1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
My Turbotemp Gas Pool Heater has error code 52 and won't operate anymore
Error code 52 on a Turbotemp gas pool heater indicates a "Water Pressure Switch Open" fault. This means the heater is detecting insufficient water flow, which prevents it from operating to avoid overheating or damage.
Mar 08, 2019 • Pool & Spa
I'm working on the 2004 Jeep Grand Cherokee 4.7 showing error codes
lashes 52 and 54 ,you do mean flashes ? What flashes ? Check engine light doesn't flash codes .
Hp laser jet printer 2055 ,52 scanner error how can solve it please
The HP Printer error 52 indicates with scanner. When you see the HP printer error code 52, then follow the steps:
·Turn off the printer
·Wait for 30 seconds and then turn on the printer
·In case the 52 error is still coming up on the printer, then make sure that the Flatbed scanner assembly is replaced
·In case the error is still being shown, the Scanner/Laser assembly may also require replacement.
Find the more HP printer error codes and their solutions. If you need any help to fix the issue contact HP Printer experts.
Error 52 on Zanussi
I believe it means
"no signal from the motor tachometric generato"
Which means Tachometer (tacho) coil on the motor may be faulty. This coil reads a magnet as the motor turns to detect the speed that the motor is spinning at and this in turn allows the electronic controller to set the motor to revolve at different speeds for the various program options.
1helpful
2answers
Airbag code 12 on 1997 ford explorer
code 12 means the battery was disconnected. the Ford dealer can reset the light and clear this code.
1helpful
4answers
Hp2300 laser printer
52.x PRINTER ERROR alternates with To continue turn off then on Possible printer control panel error messages 52.0 PRINTER ERROR 52.1 PRINTER ERROR 52.2 PRINTER ERROR Description A temporary printing error occurred. The x can equal one of the following: 0 = Scanner error 1 = Scanner startup error 2 = Scanner rotation error This error can also indicate a problem with the shutter tab on the print cartridge. Action
  1. Turn the printer power off, and then turn on the printer power.
  2. If the message persists, check the print cartridge for damage.
    1. Verify if the shutter tab on the cartridge is broken or damaged. click on the below link. Shutter tab on the print cartridge
  3. 1 - Shutter Tab
  4. Replace the cartridge if damaged.
If the message continues to persist, then download the printer software based on operating system and reinstall.
HP Laser-Jet 2300d Printer Software
Regards
Chittaranjan
3helpful
Error 52 on ricoh FT3213.
error code 52 on ricoh ft3213, that's mean heating element burn out , such as heater lamp, thermister , thermo fuse.
Airbag Error Code 52
please che.k elictric connection,2nd car computer
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
