Yes you can replace the coby dvd 224 remote with a new one, all you need to do is to get a replacement remote that looks exactly the same as your old one. You can try out that of a friend before you go ahead in replacing it with a new one. Be sure that the problem is not that the battery of the remote is weak and needs replacement or the sensor on the device you use the remote for and the remotes sensor is not bad before you can replace the remote.
Test the sensor by opening the device to check if the pin that is holding the sensor light is not rusty, if it is, then it is the light you are to replace, check the same on the remote to see if the problem is from the remote, then you replace the sensor light which is the infra red light on both the remote and the device itself.
Hope this information helped you. Thank you for using fixya.
