Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) Hope this helps
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
That did it...Thank you so much!
only glad i could help and you have your computer where you want
Sabea como restablecer de f?brica una Wyse tx0?
said to MARCO hyjacker. in spanish said
there is no F10 here (HP yes), on Wyse V10L thin net PC
also the battery is dead, if BIOS fails work right, for sure G key dead or BIOS pages from that failing.
Brian thinks this is HP PC oddly. but is now dell.com owns Wyse product line this. long ago owned
it is XPe OS for thin-net, if XPe is to be reloaded get the disks for it. there is no HDD here nor recovery here.
just old flash.
Do you know how to factory reset a Wyse tx0?
what is a TX0
Wyse
T Class Thin Clients, Model Tx0
it came new with Wyse Thinnet-OS or with Linux thin-net OS.by Ubuntu,
do you know what thin-net means/??
it is not a real computer that runs all by itself, NO.
it is thin-net that boots and the loads to a thin-net server, to be a real OS
the manual tells you the coin cell button is dead, none ever lasted 10 years.
Dell.com owns this now
https://downloads.dell.com/manuals/commo...
support for this DEVICE
is here
https://www.dell.com/support/home/en-us/...
3010 new name by dell.
it is useless for home use, best is sell it on ebay. no it will not run windows 10 ever.
I just tried this and it still bypassed the recovery console. Any other suggestions?
tiny thin client PC, mini/micro
runs XPe (special Xp only)
reset means what, BIOS reset, windows XPe recovery what?
did you just find this used for $1 or it ran for years and failed now.???
this is V10L
VIA C7 processor , from china and zero support now and useless as dead dog.(can't fetch)
the free book is here
https://www.manualslib.com/manual/957404...
this device is useless outside business, and lacking thin net system./
page 86
G-key reset is disabled for Low-privileged and Non-privileged users in
Lockdown mode
bios settings are here
While starting a Wyse thin client you will see a Wyse logo for a short period of time. During
this start-up you can press Del to enter the BIOS of the thin client to make your
modifications (enter Fireport as the password
end relics end thin-net,
end VIA< RIP VIA junk.
