Haier Energy Star ESA3183 Air Conditioner Logo
Posted on Jan 23, 2011
I have an Ager split system in my bedroom and lounge, the one in the lounge works find but the one in the bedroom shows F2 and when I turn it on it is just blowing out room temperature not cold air, then one is the lounge is fine, can anyone help me with this problem please....Maree
5 Related Answers
Anonymous
  • 750 Answers
  • Posted on Sep 29, 2008
SOURCE: blows room temperature air
Hello
Welcome to fixya.
I'm Huuum and happy to assist you
The air conditioning
unit works, but does
not cool the room
• window open
• there are heat sources in the room (burner,
lamp, etc)
• the exhaust hose is detached
• air filters clogged
• Inadequate size of the room (too large)
• close the window
• eliminate the heat source
• connect the exhaust hose
• clean or replace the filters
If all this dose not remedy the problem then you need to see service!
Please remember to leave a rating before you go!
Thank you
Anonymous
  • 700 Answers
  • Posted on Dec 24, 2008
SOURCE: I have baseboard heat in
what it sound like is that your sons room is the closest room to the boiler and is getting too much of the heates water. your room is probebly the room in the middle and your daughters is the last one. Lets start bye taking and shutting down the valves in youe sons room and or adjusting the circuit setters which is what you probebly have . THey should by on the return line and you can adjust them by just closing them down a little bit at a time or if you have a way to take the temperature of the return and the supply lines then you would try to shoot for around 10 delta t. look at the baseboard heaters where the water come in and that should be where you will find the circuit setters. Good Luck and have a Merrry Christmas
mrgrzz
Dale Koehn
  • 88 Answers
  • Posted on Jan 20, 2009
SOURCE: not blowing cold air
Sounds to me like your compressor is not operating, first check the filter to make sure its not pluged up, if thats not it, you will need a qualified service tech to come a diagnos it for you, but sounds to me like the compressor is bad, hope that helps
Anonymous
  • 5 Answers
  • Posted on Jan 26, 2009
SOURCE: Blueway split system wall air conditioning doesn't work properly.
need to add refrigerant
need to check wheather the ampere is the same on the name plate
check the room temp. setting
check the setting of the timer
John Powell
  • 7 Answers
  • Posted on May 27, 2009
SOURCE: (1.7 cu) Chefmate Fridge Doesn't Get Cold
The Chefmate 1.7 fridge uses a thermalelectric device (TED) to provide cold air. There are no moving parts there. The problem is usually in the power supply. That is the PCB on the left side behind the back cover. If the fans are running then your thermostat is bad or the TED is cracked. You can buy these ebay or other places on line. To change one you must carefully remove the large heat sink. The TED itself is only about two inches square. If you decide to replace this unit be sure to get a supply of heat sink glue. Otherwise you will end up with a hot (or cold) spot on the TED possitly causing another crack.
Top Haier Heating & Cooling Experts
Paul Carew
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
