Panasonic Viera TH-42PZ80U Plasma TV Logo
Posted on Jan 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi - we have problem with Viera tv. no sound or pic. switch on green light briefly. then straight to red light flashes 4 times then 3 sec interval then repeat. tv is just over 13 months old. any ideas.? thanks
Anonymous
Level 2:
Guru:
  • Expert 92 Answers
  • Posted on Jan 24, 2011
Anonymous
Expert
Level 2:
Guru:
Answers
92
Questions
0
Helped
26095
Points
288
Instructions Things You'll Need:
  • Damp Cloth
  • Fuse
  • TV Remote Control
  1. Ensure the power cable is securely fitted to a wall output if you can't get your Panasonic LCD TV to power up. Try testing the wall outlet with another appliance to make sure there is not electrical fault with the outlet itself. If there is still no power, a blown fuse may need replacing.
  2. Switch off the color correction option if you are using HDMI cables and the displayed image has unnatural colors. For instance, if a picture area that should be red is blue or green, then the color correction option may be the issue. Press OK on your remote control. Now access the Other Adjust option and scroll down to the Color Correction option. You can now turn the setting off, which should restore normal image quality.
  3. Press the Mute button if you can't get your Panasonic LCD television to produce sound. This may have been pressed in error, cutting off the sound. Check the volume settings on any other devices, such as a games console or DVD player, that are connected to your LCD TV. If the volume is set to low on such a device, it can limit the sound output on your TV.
  4. Check that the air vents at the lower rear of your Panasonic LCD TV are free of dirt and debris. Dirt can accumulate in these areas, causing the cooling function to under-perform. Panasonic LCD sets come with built-in safety features that shut off the power if your set becomes too hot. Clean the air vents with a damp, rather than wet cloth. Dust and vacuum the room regularly to prevent the problem from recurring.
Top Panasonic Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
