SOURCE: fan not working on fridge section of Hotpoint Fridge Freezer Model FFA90
the problem is there is a build up of ice insid of the freezer .
What you need to do is take out all your draws in the freezer and you will see a plastic backing held on with about 8 screws . undo all the screws and the back should come aay and you will see all the ice built up . just use a hair drier to melt the ice and that should cure your problem.
SOURCE: Hotpoint Ice diamond fridge freezer both green & red lights on.?
bulmer...it takes about two days to fully defrost these units unless you take the freezer section cover off and use a heat source. If you do...be sure to protect yourself against water and electricity mixing....not healthy. See below for another note.
clean the condenser coils below the unit.
check for the amount of gas in the unit. It must be off for half an hour. Remove the back fiber panel. The big thing is the compressor. Clean off the largest pipe coming out of it. Plug the unit in...watch out for the fan! The pipe should frost up and then clear off or stay wet after about 5 minutes. It should not be frosty. If it is, you need refrigerant.
Note: If you do remove the inside freezer panel and defrost, you can see how much refrigerant you have in your unit. Start the unit. Wait 5 minutes and observe the coils. They should be evenly frosted end to end. If approximately so, you're good. If not, you're low on gas.
SOURCE: red light on Hotpoint Iced Diamond freezer
hOPEFULL ONCE YOUR FRIDGE FREEZER GETS TO TEMPERATURE IT WILL GO OFF.. THIS IS THE CASE WITH THIS FRIDGE.
NOTHING TO WORRY ABOUT.
HOWEVER SOMETIMES THIS CAN INDICATE A LACK OF REFRIGERANT IF IT DOES NOT GO DOWN TO TEMPERATURE..
IF YOU NEED ANY FURTHER HELP PLEASE DONT HESITATE TO ASK
CHEERS
WASHDOCTOR
P.S. PLEASE RATE ME AS I HAVE BEEN AWAY LONG TIME AND COULD DO WITH ALL THE HELP I CAN GET LOL
SOURCE: hotpoint fridge freezer / howdens kitchen - no instructions!!
Luckily the hotpoint helpdesk admitted that the instructions for hanging the kitchen doors does not come as part of the standard instructions. There should be a seperate piece of paper with these instructions.
After some to'ing and fro'ing they managed to email me the required diagram.
