Kenmore 62602 Electric Dryer Logo
Anonymous Posted on Jan 25, 2011
I need to replace my lint trap for my Kenmore Super Capacity Electric Dryer. The one that I had was damaged and discarded. Please help!
WHISTON PORTABLE APPLIANCE TESTING
Level 2:
Champion:
  • Expert 203 Answers
  • Posted on Jul 10, 2014
Expert
Level 2:
Champion:
Answers
203
Questions
0
Helped
40478
Points
422
Try e spares on the internet they have most parts or can order them
5 Related Answers
Anonymous
  • 131 Answers
  • Posted on Mar 10, 2008
SOURCE: Dryer runs but doesn't heat up when sttings call for heat.
You may need to do some troubleshooting. This can be done with the machine unplugged - you may have to activate the start switch, belt switch (if it has one) and the motor centrifugal switch manually.
Tip for troubleshooting 220v systems - clip one lead of a ohm meter to either L1 or L2 on the terminal block. It doesn't matter which one. According to the tech sheet (under console) follow the path for current from your clipped terminal, through the heating element, to the opposite terminal. All the readings should be less than 100 ohms, until you reach the failed part. Confirm failure by disconnecting a lead from the suspected part, and test only that part.
Live troubleshooting is sometimes slightly easier, but much more dangerous than the procedure described above. - It is definitely not recommended for beginners, or for professionals, if it can be avoided.
A
Anonymous
  • Posted on Mar 12, 2008
SOURCE: Kenmore Heavy Duty 60 Series Soft Heat Large Capacity Dryer
i need to take the bottom lent door off. I have replaced the board and it still say's says to clean the lent door. i have with the one in the dryer, but need to clean the bootm .
Anonymous
  • 481 Answers
  • Posted on Jun 28, 2008
SOURCE: Kenmore 70 Series Dryer Won't Heat
first check your breaker, turn it off and back on.
Anonymous
  • Posted on Oct 07, 2008
won't heat. fuse good,breaker good,heating element test ok. How do I check the thermostate, and timer.
Anonymous
  • 89 Answers
  • Posted on May 26, 2009
SOURCE: Dropped bleach pen into lint trap. How do I get it out?
its not too hard to get out.
you will need a #2 phillips screwdriver and or a 1/4" socket driver
remove lint trap
remove 2 screws at lint trap
unplug unilt
open the top (2 clips between lid and front panel in the crack, push them with a butter knife or putty knife to release top) opens like a hood
pull out dryer and pull off rear panel
on the left hand side there is a metal duct like thing lol
that leads to the lint trap at the top.
there should be 4 screws at the bottom where it gets round.
remove them, and wiggle the duct open. your pen should be there..
Top Kenmore Dryers Experts
jdthefixer
Kolbrun...
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
